Old 09-11-2020, 08:23 AM
JR Fountain JR Fountain is offline
Default Edit/Mix window bank to selected layout?
Curious if anyone knows a way to bank the edit/mix window to the faders of a selected EUCON layout? Currently my workflow is to select the layout on the Dock and then ctrl-shift select the first track on my S3 to scroll the faders into view in the edit window. It'd be great if all I had to do was select the layout for that to happen.
FYI, I have Edit and Mix windows follow bank selection selected in my prefs.
Thx!
J.R.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 09-15-2020, 05:17 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Edit/Mix window bank to selected layout?
It's bad to assume your layout is even in the same order that it'd show up on your edit or mix window. I think this is why it's not a function.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 09-15-2020, 06:32 PM
Lynn Gräber Lynn Gräber is offline
Ryan is right. Most people use layouts to "cherry pick" tracks from all over a sessions. Banking would be impossible.
Perhaps you should be looking at VCA spill instead?
Old 09-16-2020, 02:47 PM
Good point Ryan, I hadn't considered that since I'm not using them that way. I just see the highlights around my tracks the same way as I would if I were to bank them and assumed that the edit/mix window would follow.
Lynn, I do use VCA's as well but liked layouts better because they retained the track colours and I liked instantly selecting them from the Dock instead of spilling/unspilling/spilling to change groups.
Thx!
J.R. Fountain
Old 09-16-2020, 03:28 PM
Thx!
You can spill a VCA with one touch from AC as well. There is a preference in Eucon to enable this. You can also go from one VCA spill to the next without having to unspill the previous. I am not sure why your track colors are not retained during a VCA spill. Mine are.
Old 09-16-2020, 06:16 PM
Thanks Lynn, I'll check that preference. I've always spilled the VCA's from the S3 by double clicking the select button.
The track colours might be an S3 thing, whenever I unspill a VCA it turns them green, I'm assuming to indicate that you have a VCA spilt.
J.R. Fountain
Old 09-16-2020, 07:15 PM
Ah, youre right. The little chicklets turn green during a spill. Us S1 people have the advantage of the color meter display. The things you dont notice til you look.
Edit/mix window follows bank selection brandonc23 Pro Tools 12 0 02-20-2016 10:59 AM
Edit window jumps to track when using layout Eruk Avid S1, S3, Dock and Control App 0 10-30-2015 05:22 AM
Edit/Mix Window Follows Bank Selection maxtn Avid S1, S3, Dock and Control App 14 04-06-2015 05:30 PM
edit/mix window follows bank selection Eucon/PT9? engininja Artist Series 47 11-23-2014 09:42 PM
Edit Window Follows Bank Selection. Edit Window Follows Bank Selection. Edit Window.. Focuret Artist Series 17 01-18-2014 03:53 AM
