Hey!
I've had the MBox and a iBook (700Mhz/384Mb) for a couple of months now and I'm getting a bit annoyed with it's flaws. The biggest issue for me is the mysterious bouncing problem. Anytime when I'm trying to bounce a song with CPU-usage over 40-50% it crashes. "CPU usage is holding of USB audio". I suppose that other people have also had experiences like this. The issue turned into a mystery for me when I was mixing a fairly simple song with 8 monotracks. I was unable to bounce it at all, although playback run through the session smoothly. So I decided to try a work-around. I bussed outputs from all channels that were previously routed to Analog 1-2 to a free stereobus, made a stereochannel with that bus as input and pressed rec. What happened? I had "bounced" the song. All I had to do (outside the PT) was to combine the two monofiles into a stereofile. This is when I became really interested. Why couldn't I bounce it in the first place? So, I added seven (7) more stereochannels (totaling 24) and L1 Ultramaximizer (which takes a LOT of CPU time). And? Again, the machine did what it was supposed to do. (Recorded 16 monotracks with all the plugins active.) The question is: Why does CPU usage hold off USB-audio while bouncing, but it doesn't seem to do it while recording? My logic tells me that there is a mysterious (and fundamental) bug in the software. Or maybe it's just my system. I've updated all drivers, minimized extensions, turned off TCP/IP etc. I have tried every trick I have found, but haven't been able to make it functional. Can anybody give me advice on this? Hannu Oskala Helsinki, Finland |
I get the same problem. My workaround is to unplug all other USB devices. Not always possible if you're using USB dongles though.
Mac Computers/PT12/Lots Of Lacie D2s |
![]() Quote:
This is truly a mysterious thing. |
Hi Hannu,
What program do you use for combinig two mono files into one stereo file? Thanks Capi Lima Peru |
MBox Mini and Headphones Mystery | HostMary | MIDI | 6 | 02-12-2013 09:20 AM |
Is there a solution to the bouncing midi folder yet? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-16-2010 01:31 PM |
mbox mystery | RShindell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 02-01-2005 06:16 PM |
Help me out of this mystery MBox\LE6.1 | SilkyRay | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-10-2004 09:58 PM |
Finally a solution for bouncing midi to wav! | theregressor | Digidesign Hardware & Software | 0 | 11-18-2002 08:16 PM |
