Error when launching Pro Tools 11 after fresh install
Installed a fresh copy of Pro Tools 11 on a Macbook Pro Retina with 10.8.4 on it. Here's the error:
Could not create a new document because Assertion in "/Volumes/Development/105109/AlturaPorts/DFW/MacBuild/../Views/UMenu.MacOS.mm", line 1357. (Use the Copy button to copy this message to the clipboard.). Tried cleaning and reinstalling and no luck. I cannot open Pro Tools at all. This is the second machine I've installed Pro Tools 11 on and had two completely separate issues. Avid...can you help? |
Re: Error when launching Pro Tools 11 after fresh install
And everything is OK with iLok? V2 USB and all the right licenses?
Can you list your system specs?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Correct. I have a MacBook Pro Retina 2.3GHz i7 with 8GB RAM. Running OS X 10.8.4
ilok is working with my Pro TOols 10 license. |
What about your PT11 license ???
PT11 specifically requires iLok2 key, the new black one. PT10 works with the old blue key as well. Be sure you have the correct key!
Not sure why my license is in question but just to clarify...yes I have an iLok 2 (black) connected to my machine, but get this weird error. Has anyone at Avid seen this?
I cannot launch Pro Tools at all, but can verify my license is good and shows up in my ilok account and key, because I am able to launch Pro Tools 11 on another machine with my iLok key. Anyone else run into this? |
Having the same kind of problem.
Using ilok2 |
Same problem, also on 10.8.4. Might be that 10.8.4 is the problem? I read it is not supported....
Do you have avid hardware? Just found out changing the playback engine to internal solves the problem. Selecting my MBox causes it not to work anymore.
Yes, that is it for me. Downloading latest drivers for MBox solved it:
http://akmedia.digidesign.com/suppor..._Mac_78311.dmg |
Elastic Audio plugin Error msg on fresh install of PT 11 Windows | Justin1524 | Pro Tools 11 | 8 | 10-17-2013 12:05 PM |
Pro Tools will not open on fresh install | jeff5x0 | Pro Tools 10 | 15 | 02-16-2013 09:02 AM |
Pro Tools 8 LE really buggy on a fresh install | rubberhead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-21-2012 01:01 PM |
Fresh install of Pro Tools Le 6.4 | cherrancemetal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-01-2011 10:21 AM |
Pace Register Error during reboot after fresh install of PT 8 | DeyBwah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-14-2010 05:23 PM |
