Old 11-04-2006, 05:56 AM
Darkk927 Darkk927 is offline
Default different pan settings on same track??
Hey, ive been working with pro tools mp for about 3 months now, and still havent been able to figure this one out.
I know that you can set pan levels for each track, but is there any way you can change pan settings on the same track?
for example, i record a 30 second guitar riff. The first 10 seconds are panned 100 perecnt to the left. The next 10 seconds are panned 100 percent to the right. The last 10 seconds are panned to the center.
is this possible?
thanks
Old 11-04-2006, 06:25 AM
spkguitar's Avatar
Default Re: different pan settings on same track??
Of course it's possible.
You need to automate the pan settings. Check out Chapter 27 in the Reference Guide (available from the help menu within the program).
Short and sweet, in the edit window, switch your track's view to "Pan" and write automation with the pencil/grabber/trim tools. You can edit it so that the change is gradual, moving over time, or set it so that it "snaps" to the other setting at a given spot on the timeline.
Old 11-04-2006, 06:59 PM
o WOW thanks spk, that makes things a lot easier.
and btw, what does automation mean? does it mean that you use the pencil tool to change values?
Old 11-04-2006, 07:14 PM
spkguitar's Avatar
Automation: things that happen automatically. (did you even read Chapter 27?)
Copy EQ settings to new track Ginridge Getting Started 7 09-24-2016 04:54 AM
Copy EQ settings to new track Ginridge Pro Tools 10 4 05-30-2013 11:30 AM
Track Settings AHorrorstory.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-14-2004 05:30 PM
Export Track Settings - possible? FrankEEE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-10-2004 04:49 PM
Copying track settings? jonnyrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-31-2003 10:21 AM
