Old 07-07-2005, 05:56 AM
malfunction malfunction is offline
Default Tightening up the bass?
Anyone have any tricks / methods they'd like to share for tightening up the bass in PTLE...?
Thanx
Grant
PT9, Zed R16 & Macbook Pro i7 2.66Ghz
Old 07-07-2005, 06:03 AM
davetron5000 davetron5000 is offline
Default Re: Tightening up the bass?
You could sidechain the bass compression to the kickdrum (use it as the key trigger)
MacBook Pro Core Duo 1.83
2 Gig RAM
OS X 10.4.8
002R/PTLE 7.3.1
Old 07-07-2005, 07:29 AM
brinaddison brinaddison is offline
Put a high pass filter at about 40Hz then give the bass a boost at 300Hz and cut the 300Hz from the Kick drum quite radically. This should help in placing the kick and bass. Also do as the first poster said and sidechain the comp to the kick.
Next is to cut all the low freq information for anything that does not require it, such as Gtrs, Vox, SN etc... (high pass at 100Hz-220Hz or appropriate low shelf). This will help to give the bass some room to move and will save energy in the mix.
www.hypeschwartz.com
Digi001
(RME adi-8 pro)
G4 MMD Dual 1g + 1.25g RAM
PTLE 6.4 (DVToolkit)
Mac. OS 10.3.3
3 Lacie 80g FW Audio Drives
Tightening Bass Lines algy Tips & Tricks 11 06-15-2013 10:19 AM
Record bass w/ Ampeg SVX - just plug bass into MboxPro or go in w/ DI like SansAmp? Squid Vicious Eleven Rack 10 12-31-2012 01:46 PM
tightening up a guitar track nwarren1981 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-08-2009 10:58 PM
Tightening drum performances ondruspat Tips & Tricks 3 05-18-2006 12:09 PM
Tightening up a bass guitar Punx Tips & Tricks 10 04-23-2003 10:17 PM
