Old 05-05-2022, 08:53 AM
Reckless Erik Reckless Erik is offline
Default Custom plugin mapping
To the hive mind....or Jeff.
When creating, for example, a custom control knob mapping for an eq plugin on the Avid control app/Dock, where is this mapping stored? Is it specific to the open session only or is it something that can be transferred between sessions?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 05-05-2022, 09:35 AM
creativecontrol's Avatar
Default Re: Custom plugin mapping
You can find the maps for EuControl here ->
https://www.dropbox.com/s/xpu799hqj6..._Maps.png?dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-05-2022, 09:41 AM
Thanks Jeff. Can there be more than one? Can you rename in the finder?
[email protected]
Newcomer Audio Post
Old 05-05-2022, 09:45 AM
Here's more detail. An individual XML file is created when a custom map has been programmed (regardless of width). Here you can see some of the maps I've created - some of these started on S6 - 4x2 MTM -> and can be used on the encoder columns on the Dock.
https://www.dropbox.com/s/aozxptn8a4..._Deux.png?dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-06-2022, 03:58 PM
Looks good. And how are these mapping profiles loaded? When the specific plug is opened? Or some other way? Can you have multiple profiles available for a plug that can be called up depending on your own workflow. I'm using the dock and a couple of S1s.
[email protected]
Newcomer Audio Post
Old 05-06-2022, 04:28 PM
BScout BScout is offline
Originally Posted by Reckless Erik View Post
Looks good. And how are these mapping profiles loaded? When the specific plug is opened?.
Yes
No.
You get one custom map per plugin. And then you always have the default map. (These custom maps are stored in the Eucon profile for the program that's in focus. So you could have a different map for the same plugin between different applications like Cubase vs Pro Tools.)
Old 05-06-2022, 04:38 PM
Thank you BScout. Very helpful. I guess I could create some different profiles, store them in another location and pull them in as needed.
[email protected]
Newcomer Audio Post
Old 05-17-2022, 03:05 AM
Cheesehead Cheesehead is offline
Hi Jeff
I see you have a custom map for pro Q 3 in that folder.
How does that work?
I've never been able to successfully create one because the plugin bands always seem to be out of sequence when I create them.
Do you use a fixed number of bands in a preset?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-17-2022, 06:12 AM
Greetings,
A few questions. Would you like to create an Insert Parameters map (teal) - for example to interleave dynamics parameters in addition to standard EQ parameters? Or - are you modifying the dedicated EQ map (magenta) to optimize how the basic EQ is laid out?
Also - as a general recommendation - I would always start with a Flat 7 bands preset with FabFilter and work from there.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-17-2022, 12:15 PM
Hi Jeff,
I tried modifying the dedicated EQ map as I don't tend to use the compression features as much.
I tried with the flat 7 bands but the eq nodes are still out of sequence on that, unless I'm doing something wrong.
I don't suppose you have a custom map you could share do you, it would be great to see what you've done to make it work?
Thanks
Martin
ps sorry for hijacking Erik's thread.
S1 Custom Mapping not working traksion Avid S1, S3, Dock and Control App 4 07-25-2021 09:31 PM
S1 custom mapping FF-Q3 Frank Kruse Avid S1, S3, Dock and Control App 6 07-21-2021 07:57 PM
Custom plugin mapping for knobs?? stefanboman Avid S4/S6 24 06-29-2021 06:56 AM
Custom plugin mapping marsian Avid S1, S3, Dock and Control App 2 05-29-2019 07:45 AM
Custom Plugin Mapping with Nuendo? J-S-Q Artist Series 2 04-23-2015 03:02 AM
