6.4 firmware upgrade?
Hi!
I'm currently running 6.1.1 on a 002 rack and it's solid. My question is, if I upgrade to 6.4 and the firmware is updated and I for some reason find that my system isn't working as well as previously, will I be able to go back to 6.1.1 or will the updated firmware prevent me from doing so? |
Re: 6.4 firmware upgrade?
I don't know but I did the same thing. Hope not.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
As fo myself, I think I'll wait until someone can confirm that you can switch back to 6.1.1 before I make the move, just to be sure. Anyone who tried? Maybe some of you guys with controlers that that is no longer supported? |
I upgraded the firmware on my 002 last night while installing 6.4 update.
Then I plugged 002 into my other PC (6.1.1), and received a message saying my firmware is incorrect, but I ignored it, and it seems to work fine. I sometimes wonder if Digi's software people have ever worked in the real world.
Quad 2.5 G5, 4.5G RAM |
If you go between different versions (6.4 to 6.1.x) you can download the correct firmware on each system - so, yes, you can revert.
Rail
Rail, I'm not sure I get what you mean, will the firmware be reverted too if I go back and install 6.1.1 or would I have to do that manually, and if so, how? |
If you plug your 002 into a system running an older version of Pro Tools you'll be prompted to upload the firmware to match the version of Pro Tools running -- like for example on my PC I have 6.1.1 and I uploaded he firmware for 6.1.1 into my 002... if I now take my 002 and plug it into my old Mac PowerBook running 5.3.2 I'm prompted to upload the firmware.. so I do. When I go back to 6.1.1 on the PC I upload it again.
As has been mentioned running the wrong (mismatched) firmware version may work okay.. but I wouldn't recommend it. Rail
Ok, I get it!
Really appreciate your help! I will try to update tomorrow as it is getting kinda late here in Sweden, gotta get my beatysleep! Once again, thank you! |
Firmware upgrade on 003 with PT9 | shobud | Windows | 3 | 05-06-2013 10:23 AM |
Did somebody upgrade MC Mix firmware? | Durcu | Artist Series | 2 | 02-15-2011 12:17 PM |
Mac G5 Firmware Upgrade | MidiMe | Pro Tools TDM Systems (Mac) | 5 | 01-03-2005 05:12 AM |
002 firmware upgrade | Antihero | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-26-2004 06:05 AM |
002 r firmware upgrade ? | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-23-2003 05:47 PM |
