Problem recalling flat EQ in plugin
Hello,
We are using a Digidesign Venue Profile console and are having some trouble recalling an EQ plugin with flat settings. Here is what we are experiencing: Create EQ for a scene and store to library/snapshot Create EQ with flat settings and store to library/snapshot Recall first library/snapshot, proper EQ is recalled Recall second library/snapshot, the EQ is not flattened, there is no change. This has happened with the Waves Renaissance EQ 4 band plugin as well as Waves EQ 4 band. |
Re: Problem recalling flat EQ in plugin
If I recall correctly, the same plug-in did/does the same thing in ProTools. I've read a thread or two in the ProTools forums, but not sure if there is a solution. Odd that it would happen in the venue as well.
Ken Miller, Jr. Audio Engineer Southside Baptist Church | Warner Robins, GA | VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Hi there.
Sounds like one or both of these things is happening. 1. Be sure that you have added that specific plugin to each snapshot you want to recall. (While the snapshot is loaded, navigate to the plugin page, and clicking the "S" button in the lower right-hand corner of the EQ plugin, and choose "add plugin to selected snapshot" or something like that.) AND... 2. On the main snapshots page, make sure "PLUG-INS" is scoped for each snapshot. -chris |
Or, what Ken said. I do now recall reading about that as well.
The plugin is added to the snapshots and is in scope for them. Any other ideas?
I would talk to Waves. Their support is supposed to be pretty good.
You could also try a different EQ plugin. Dave
David Stagl - Mixer | FOH Engineer http://www.staglproductions.com http://www.goingto11.com |
We are on D-Show 2.8.6.247, and I'm on the latest Waves V8 install. |
We've got an email in to Waves but their D-Show specialist was not in today.
Thanks for trying to recreate the problem, our rental shop supplied us with Waves V5, and we are on D-Show 2.8 as well, so we are pretty sure that is part of the problem. |
TC VSS3 TDM not recalling settings | JSR | Pro Tools TDM Systems (Mac) | 42 | 09-09-2012 08:35 AM |
EQ3 Not recalling/saving settings | slaterweezer | Pro Tools TDM Systems (Mac) | 0 | 04-09-2012 10:42 AM |
Pt8 not recalling the previous setup | Dj-Ike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-24-2009 12:37 PM |
Sound Toys not Recalling | ChsGlvr | Pro Tools TDM Systems (Mac) | 1 | 08-28-2009 04:27 PM |
Is there a Bug® with recalling zoom settings?? | Bushpig | Pro Tools TDM Systems (Mac) | 11 | 07-13-2009 02:49 PM |
