Should I sell my G5 quad?
this post isn't meant to be whining or complaining...anyone who's been on here long enough is sick of all the silly complaints that go on ( although some are valid.) I'm a music composer who's basically frustruated with RTAS performance in PT LE. When I see how well Ivory piano module runs, I know it's possible. I run alot of soft samplers at lower buffer settings, which is the RTAS issue
I know I got myself into an unstable work situation by purchasing an unqualified computer. However, it will be almost 4 months now of CPU spikes and I really might be ready to throw in the towel with Digi and Native Instruments. Native Instruments...Kontakt 2...god help us...I will not buy from them anymore... This is really just a question to bounce off of other quad users running PT 7.0 Hardly any of my plug-in companies have optomized for PT 7, and there are no updates in sight. (altiverb 5, sony bundle, izotope, trash...) Anybody with a constructive opinion, please chime in... Is anybody having great results with Logic Pro on their quad? I really wonder with Digi probably having to scramble for intel codes, that maybe this is just a bad time for incompatibility due to lack of resources at these companies. Perhaps the quad is never supported? pardon my rambling... -CV |
Re: Should I sell my G5 quad?
I'm facing a somewhat similar dilemma.
Although I'm able to make it though a project fine on this machine (not without complications of course)...I'm paying for more machine than I'm using. I too, contemplated selling my Quad... the problem is, for the price that I paid for the Quad direct from Apple a little over a month ago.. people on Ebay are selling new Quads with 8 Gigs of RAM, 500 GB hard drives..etc For cheaper, or around the same price as getting it from Apple with only 512 RAM, standard 250GB Hard Drive... so you are guaranteed to take a drastic hit if you bought directly from Apple with minimal specs and try to sell on Ebay....because, the folks with the new, loaded Quads have the better deals. In your situation though, it seems that you are being prohibited from getting anything done on this machine without months of jumping through hoops... so, I'd say let it go and try to deal with the loss. It shouldn't have to be that way though. |
Garjaye...
thanks for the input... Selling the quad won't resolve all of my issues though as a big problem is PT 7 and its RTAS performance bugs. I guess I've come to realize that Pro Tools LE is just not the best system to run for a Pro Level composer who needs to run virtual instruments and mix / compose simultaneously. I'm also running a Muse receptor to take some of the burden off LE and the quad...I bought it after seeing the poor results with the quad just very frustruating after the thousands of $ I spent... cheers, CV |
Logic would probably scream on your Quad, I've got a dual 2.5 and it's heaven. I'm not a big fan of Logic's audio mix bus, but it works fine for quick demo 'on-the-fly' mixes of MIDI scores, but when it comes to the final mix I bounce everything out and do my mixing in PT. If you can afford to have both, you'll have the best of both worlds - however I also recommend NOT using a Digi interface with Logic, the Digi CoreAudio drivers are pretty weak, I use an M-Audio Firewire box and it's great, and that new Apogee thing looks amazing. |
Slim,
thanks. awesome!...very insightful response. Could you please briefly describe your method of moving a session you've written in Logic over to pro tools for mixing. Is it simply a matter of printing all of your midi to audio stripes, or is there some sort of conversion tool. It just sounds very time consuming, especially when you're under time constraints. Also, with automating plug-ins, tweaking VI midi, wouldn't you want to do final mixes in the session/program you've been carefully adjusting for the past 12 hrs? I'm always tweaking Kontakt2 right up to the final print (and holding my breath for crashes.) cheers, CV |
This is a little off topic, I'm running M-Powered on a G5 iMac and am considering a Muse Research Receptor, probably for the same reason you got one, to offload host CPU processing. Is it worth the investment?
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
On the Receptor:
I'm actually in the process of checking in with their tech support to see if I'm not doing something right...I haven't been overly pleased with its CPU load especially with Kontakt 2 and Kompakt. I can only run one instance of Kontakt and one instance of Symphonic Strings before its CPU is overloaded. I was hoping to be able to run at least 3 or 4 large instruments... Otherwise its a great interface. Uniwire looks promising, but not for Pro Tools users as it's not supported... and back to the orginal topic... Slim ( or anybody else)...thanks so much again for your input. I'm seriously thinking of getting DP or logic. Have you noticed better midi timing with these programs? PT has some serious issues with midi timing slop. It actually seems to have gotten worse with newer versions. cheers, CV |
I'm having issues with MIDI too on the Quad, but mostly just a heavy CPU load. However after doing some testing today, I found that even at 64 buffer setting I'm able to play MIDI quite fluidly from my AXON guitar MIDI interface. My problem comes when I need to change the patch, things get very sticky. I'm using Sampletank XL 2.1 (I used to like it but since upgrading my monitors to Dynaudio BM15a's I'm really hearing some crappy sound samples coming out of it) berrrr!!!
My real issue is BFD lite. It's a session stopper all on it's own! As far as slop is concerned... I thought it was my AXON which is normally really good at tracking (Neural Network system) but you're right, it might be Protools. |
I've just used the quad for a mix with a 002rack and the power was amazing. It seemed to have endless resources. The session was 24bit at 44.1 with a full track count plus many virtual tracks in the session.
Plug-ins used: URS N & A; SSL4000; Nomad Factory; Waves Gold; McDsp Analog Channel..never a glitch...7 days straight. Although, I'm not so sure that they will be supported anymore once the Intel versions come out. The Quad was just a stepping stone from Apple. |
2008 Harpertown quad 3.0 to 2010 Westmere quad 2.4??? | audioluche | Pro Tools HDX & HD Native Systems (Mac) | 2 | 11-15-2012 06:14 PM |
G5 5 quad versus dual quad | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-09-2010 06:50 PM |
AMD Quad Memory to Intel Quad? | ChazC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-29-2008 04:36 AM |
Quad G5 vs Quad Mac Pro (known LE issues) | John J. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-08-2006 10:23 AM |
