Old 07-01-2022, 02:03 AM
thin ice thin ice is offline
Default Re: Pro tools 2022.6 released
Originally Posted by BCnSTL View Post
I predict native M1 support will come mid-to-late 2023 - at the earliest. I’d love to be wrong.
I've given up worrying about this, as it requires every plugin you have to be native as well. There is no hurry if things are stable and I'll upgrade the computer if I need more power
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3
Old 07-01-2022, 05:15 AM
LoudBassTone's Avatar
LoudBassTone LoudBassTone is offline
I feel the same way. I read somewhere that Avid was ok with Pro Tools performance through rosetta for now. As long as I can work, I’m good.
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries.
https://www.youtube.com/channel/UCmT..._as=subscriber
Old 07-01-2022, 09:03 AM
JingleDjango JingleDjango is offline
Is anyone using Custom Shuttle Lock speeds successfully in this release or with 2022.05?
Old 07-01-2022, 10:11 AM
Franklyn Franklyn is offline
I find out something interesting.
Some new Silicon ready Plug Ins like Sonnox (Inflator, Limiter) and UAD are still U2B on AAX when you read them with "ArchiCheckt"
Maybe there is something coming soon?!?
Old 07-01-2022, 10:38 AM
mtmusic mtmusic is offline
Default Re: Pro tools 2022.6 released--selection of midi notes disabled after quantize
Originally Posted by bashville View Post
in the MIDI editor window--selected and quantized a couple bars of a pattern. After that, the events that were quantized could not be selected/moved. I can hear velocities being adjusted using the velocity trim, but the graphics for the notes don't move. So no note trimming, moving the note, any further editing after the quantize operation. See attached screen grab after using the i-beam to select a range of time. Selecting the notes to the left worked fine (they had not been quantized)--notes to the right had been quantized, and are not selected in the i-beam sweep. Long time PT user--not sure if some preference has been changed that I missed.
I'm also having a new and extremely annoying MIDI issue after updating to 2022.6 today that seems related. Sometimes when I double click and create a new MIDI note, I'm unable to actually select that note to click it and drag it around. I can use the trimmer tool to shorten or lengthen the note, but I can't select it with the grabber tool, and the i-beam tool just goes right over it. Is anyone else getting this?
File Type: jpg Screen Shot 2022-07-01 at 1.35.41 PM.jpg (51.0 KB, 0 views)
Pro Tools Studio 2022.9
macOS Monterey 12.5.1
Macbook Pro 2021, M1 Max, 64GB RAM
Universal Audio Apollo x16 (x3)
Old 07-01-2022, 11:37 AM
smurfyou smurfyou is offline
Yes works fine. Were you in that other thread about it? Could be another arbitrary Ultimate-only feature.
~Will
Old 07-01-2022, 01:49 PM
Eric Lambert's Avatar
As I understand it, there are ways to structure plugins under a Native DAW such that the M1 plugs operate natively while the non-native plugs do not. I don't believe it's a case of the entire plugin folder being dumbed-down to the architecture of the weakest link.
Assuming this is correct, AND that Avid pursues this type of design, maybe there's hope. The alternative is grim because I'll *never* get Native versions of everything I use.
Old 07-01-2022, 02:01 PM
off the wall's Avatar
Originally Posted by Eric Lambert View Post
I also had high hopes when I saw that email come in, but I think it's still going to be a few months before we see Native. 2022.10?
A year ago, I predicted a 2022.12 Native release at the earliest and I'm still sticking to that - maybe even a bit more pessimistic at this point.
offthewallproductions
Old 07-01-2022, 02:56 PM
Dizzi45Z Dizzi45Z is offline
I am having the same problem and even worse, if you quantize multiple times, it duplicates the notes to the new position. But yeah, after a quantize or two (with the new or old methods) you can not move or select the notes.
Too bad. I was liking the list of bug fixes, but this new bug is a deal breaker for me. I'll be sticking to 2022.5 for now.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 07-01-2022, 03:11 PM
It's never been restricted to Ultimate before and in my conversation with support they never suggested that might be the reason it wasn't working.
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 Alécio Costa Pro Tools 4 06-01-2022 11:58 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
EUCON 2022.4 Released EddieJones Avid S1, S3, Dock and Control App 17 05-08-2022 07:26 PM
EUCON 2022.4 Released EddieJones Avid S4/S6 0 04-29-2022 03:32 PM
Ozone 9 Advanced Version 9.12 released April 8, 2022 gives AAX Plug-ins 0 04-10-2022 02:27 PM
