Old 09-18-2018, 01:12 AM
xrekcor's Avatar
xrekcor xrekcor is offline
Default 2018.7 on mOS10.13.6 Layered Editing function not working?
Hi Folks,
When I am working with audio clips in the edit window, and whenever I lay one over another while moving clips about, it always takes a chunk equal to the area that was laid across.
Now it is my belief that this should happen depending on whether I have "Layered Editing" button enabled or not enabled right? or am I missing something here.
I want to be able to move clips about without snacking on others.
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2021.3.0 -23.# - HEAT applied, Cubase 9.5,
Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 09-19-2018, 12:56 AM
innesireinar innesireinar is offline
Default Re: 2018.7 on mOS10.13.6 Layered Editing function not working?
It's broken since the 12.8.3
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2021.3 - Cubase Pro 10
Mac Pro 5.1 quadcore 2.8 32GB Ram - Mac OS 10.13.6
Old 09-19-2018, 02:55 AM
xrekcor's Avatar
ok thanks
Rob
Old 09-19-2018, 06:04 AM
KV626's Avatar
KV626 KV626 is offline
works fine here (2018.7)
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Layered Editing issue on 12.8.3 innesireinar Pro Tools 12 1 01-10-2018 11:11 PM
12.8.2 Broke Layered Editing Feature?? thanos4 Pro Tools 12 9 11-26-2017 11:00 AM
Bug: Layered editing can't be disabled daeron80 Pro Tools 12 3 10-27-2017 05:55 AM
12.6 Layered Editing? ptfigg Pro Tools 12 6 11-30-2016 10:58 PM
12.6 layered editing not what it should be pyrmont25 Pro Tools 12 8 09-29-2016 03:02 PM
