Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 11-02-2022, 09:47 AM
dominicperry dominicperry is offline
Default Re: Avid Carbon Central
Yes, well unbelievably this is an Intel binary rather than Apple Silicon native, so it's actually consuming resources unnecessarily if you are running Carbon without Carbon Pres.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 10-14-2023, 09:22 AM
scremedy scremedy is offline
Hello.
So i've had a couple carbons for two years now in different studios. Just purchased a carbon | pre to expand one system. I've loaded Carbon Central, run firmware updates etc.
Not able to adjust clock settings in Carbon Central. I understand that need to "disable" Carbon & Carbon Pre from AMS (Mac OS audio midi setup) and use Carbon Central but i must admit that i don't know what you mean by disabling in AMS.
Would you mean:
1. Simply making sure that in Audio Midi Setup some other device (ie...macbook internal speakers) is selected and not the many Pro Tools Carbon interfaces...
2. Delete Carbon interfaces from AMS?
Some clarification is appreciated. No dumb questions, right?
If it's #2 - then when i'm actually at my other studio running a solo Carbon - how should I best use it?
Thank you.
Scott
ProTools Ultimatte 23.3.0
Carbon
Carbon | Pre
MacBookPro 2019 / 2.4GHz 8core Intel i9 / 64GB DDR4
Mac OS Big Sur 11.7.7
File Type: jpg Screen Shot 2023-10-14 at 9.17.19 AM.jpg (24.9 KB, 0 views)
File Type: jpg Screen Shot 2023-10-14 at 9.17.39 AM.jpg (47.0 KB, 0 views)
Old 10-14-2023, 10:04 AM
Go into AMS and launch the Network Browser (CMD-3) and untick Carbon.
You can't change the clock speed using Carbon Central. A bit of an oversight. You have to do it from inside PT. Which is uselss if you want to use a different DAW.
Dominic
Old 10-14-2023, 10:07 AM
better image
Old 10-14-2023, 08:32 PM
Thank you. i'll give that a spin.
Can Avid Carbon(PRE) be used together with HDX ? pm mastering studio Pro Tools | Carbon 3 10-21-2022 05:17 AM
FS Avid Carbon tomhartman Buy & Sell 0 11-30-2021 08:22 PM
Using Carbon with Avid Sync HD? akhafaji Pro Tools | Carbon 1 01-18-2021 12:03 AM
Avid Carbon Review in Recording Mag musicman691 Pro Tools | Carbon 5 12-06-2020 11:27 AM
