Old 04-27-2001, 05:22 PM
Mark Wheaton Mark Wheaton is offline
Default bounced files have Garbage at end
I have been bouncing mixes using Master X and sometimes, NOT always, the bounced file will have random garbage noise at the very end of the bounced file. If you reimport this you can see it. I then need to changed the region size, create a new fade out or just separate and Export definition to get a clean file. Is this a bug? I would be happe to send a session like this to Digi to see if necessary. I wonder if anyone else has this problem. by the way this is in small sessions with start times of 00:59:00:00 or so and are no more than one hour or less including within minutes of the start time. these are sessions with small numbers of tracks and very few plug-ins. Also, if several regions are bounced only some have the problem.
mark@catasonic.com
http://www.catasonic.com
Pop at the end of bounced files brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 11 07-25-2011 06:42 PM
Bounced Files are Silent 2hip2b4real 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-27-2010 05:48 PM
Volume too low on bounced waw files digidane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-15-2009 05:49 AM
Bounced files end gets cut off breakie Pro Tools TDM Systems (Mac) 8 05-25-2005 01:26 PM
Bounced files shameeta General Discussion 4 11-09-2003 07:36 PM
