Old 10-12-2011, 11:25 AM
Pluck Pluck is offline
Default Connect iPhone to Eleven Rack
I just got an iPhone, and I want to record some of the music apps into Pro Tools through Eleven Rack. I tried connecting the iPhones headphone output to 11r´s Line in and the FX return. They both sound terrible. Does the iPhone have some kind of line out option? Has anyone here tried recording the iPhone through the Eleven Rack? If you have, I´d love to hear how you achieved it.
iMac i7 3.4 GHZ, 8 GB RAM
Pro Tools 10, OSX Lion 10.7.2
Old 10-12-2011, 11:52 AM
Default Re: Connect iPhone to Eleven Rack
Common iPhone docks give you stereo line out. Start there.
There are higher-end docks (e.g. from Wadia) that provide S/PDIF output. I have no idea if that will work OK with other apps as compared to iTunes. But that would be something to play with if there was a need to get a higher-quality recording.
Put your phone in airplane mode to avoid RF interference.
Remember each 1/4 inch guitar input or FX return is mono and you need to split from the mini-jack to two TRS plugs if you want to come into the Eleven Rack as a stereo return. Don't use the guitar input for line level inputs. If you plug a stereo TRS plug into a mono TRS FX return send jack it will sound like crap (you'll hear a distorted L to R difference signal).
Some iPhone music apps allow you to record to the iPhone. You would likely get much better results doing that and transferring the recorded file to Pro Tools.
Darryl
Old 10-12-2011, 12:41 PM
Hotcrazyfruit Hotcrazyfruit is offline
Get a 1/8" male (stereo) to 2x 1/4" male (mono) plugs. Use the left and right line inputs on the back. Select Line Input L/R In protools to record from that source.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20)
12 GB Patriot Viper Extreme
Asus P6T
OCZ Agility 64 GB SSD
Hitachi 1TB 32 MB HDD
WD Caviar Black 500GB
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Fender Super Champ XD
Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet
Old 10-12-2011, 10:15 PM
zedhed's Avatar
zedhed zedhed is offline
Out of curiosity, what format/s (file extensions) are the 'music apps' in the iPhone?
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.3.2) Omni s/pdif w Eleven Rack
HD 96I/O
Win 10 Pro
Old 10-12-2011, 11:13 PM
Ah iOS apps are apps. The app file has a file extension .app. But I don't suspect that is really what you were asking...
iOS CoreAudio is very similar to CoreAudio in OS X and provides core file/format support for AIFF, (.aif, .aiff), CAF (.caf), MP3 (.mp3), MPEG2 or MPEG4 ADTS (.aac) MPEG4 (.m4a, .mp4), and WAV (.wav). What audio files, if any, an audio/music application supports if up to it. And remember you still have to suffer the walled garden/lack of true filesystem in iOS.
Darryl
Old 10-13-2011, 02:55 AM
I actually got a dock with the phone, but didn't notice the line out plug until you mentioned it. To bad it doesn't come with some kind of break out cable though; playing a keyboard on the phone screen is not very easy while it's docked.
Yes, that's exactly what I heard when trying to connect the phones headphone out to a mono FX return. Very weak, distorted signal. I'll try splitting the signal and see how that works.
The Yumi:Synth app (Supposed to be a realistic sounding bowed instrument, but sounds more like a ribbon controlled mellotron) is the main reason I'm trying this. Unfortunately it doesn't have any built in recording abilities.
Nick
I tried this as well, but I didn't split the signal. I just went from the headphone outs to Line Input L. It did not sound good. I can't really put my finger on it, but it sounds like it's loosing a lot of low end and top end. I suspect the iPhone headphone output is the culprit. I also noticed, when going the Line In route, that the sound is very delayed (after pressing a key on the phone, it takes a second for it to arrive in Pro Tools).
Old 10-13-2011, 07:55 PM
Ensure there are no eq's or compressors on the Line input channel, and make sure there are no sends.
The delay is most likely due to your buffer size.
Also, Mono does NOT sound very good if your trying to listen to music.
Your going to want to split the signal if you want it to sound proper.
Nick
Asus P6T
Saphhire HD 5850
3 x 20" monitors
Eleven Rack w/ ERXP
Old 10-13-2011, 09:10 PM
zedhed's Avatar
Darryl
Thanks Darryl,
I like to try and understand the 'inner workings' of these things
HD 96I/O
Win 10 Pro
Eleven Rack won't Connect to Omni IO Regg-4 Eleven Rack 1 10-19-2013 11:08 PM
How to connect the Eleven Rack and a Pod HD together webstersp Eleven Rack 5 01-04-2012 05:02 AM
Simple Mixer for Eleven Rack and iPad / iPhone Sorefingers Eleven Rack 1 11-29-2011 05:52 PM
Eleven Rack Won't Connect bloodbath666 Eleven Rack 1 03-24-2011 06:03 AM
Eleven Rack won't connect spandol Eleven Rack 2 02-02-2011 09:32 PM
