After starting with PT 9.0.2. about a week ago I'm quickly getting used to the workflow and I'm already getting some serious work done.
But, there's a few things I've run into that don't seem possible yet and I was wondering if there's any idea if and when this will be made possible? - Continuous recording of MIDI and Automation when loop recording. This seems to be a serious no go. I would expect a continuous recording, but instead each loop the recording restarts. I sometimes even lose connection with the fader. And if you play a little ahead of time your basically out of luck. Recording automation is also a bit of a bummer, when recording automation of a filter cutoff I usually have several passes of automation recorded. But with PT it's kind of frustrating as the recording is reset on each loop. - Faster then real-time bounce. Although I realize this isn't likely to happen soon. But having only-realtime is getting a real workflow killer in certain stages. - Bounce instrument parts. I often program drums, or record instruments in midi. Regularly I bounce these to audio to do some further processing, glitching and cutting up samples. But unlike many other DAWs I have to actually record the audio ouput of my VSTs. It would be great to have PT automatically create an audio part in a single click. Much like Logic's bounce in place or Studio One's bounce instrument parts. - Bounce stems. Quite regularly I collaborate with friends and have them do remixes or re-edits. A feature that I'm really missing and that seems to be somewhat of a hassle to workaround is the possibility to bounce stems. It's pretty much inline with the Bounce Instrument Parts. Thanks guys ;-) And just to be clear, I really like PT. Just missing some things that would make it even better. |
If you don't want to bounce VI's, insert them on an audio track rather than an instrument track (instant record) then just move the VI onto a new audio track to do another part if necessary.
Or if you have a good computer you should be able to create multiple instances (separate midi tracks) of VI's (each with their own corresponding channels to audio tracks) for separate parts.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Thanks, great tip. Especially useful when the plugins have their own build-in sequencer.
Windows 7 x64 SP1: Asus M2N68-AM PLUS - AMD Athlon II X4 620 (4x 2.6 GHz) - 2 GB Ram - SSL Duende Classic - SSL MX4 Windows 7 x64 SP1: Dell Latitude E6410 - Intel Core i7 - 8GB RAM - PreSonus FireStudio Mobile Mac OS X 10.6.7: iMac 21,5" - Core i3 - 8GB Ram - PreSonus FireStudio Mobile PreSonus Studio One Pro 1.6.4 || SSL SoundScape v6 || Pro Tools 9.0.2 AIR Users Blog NL |
Sure you can bounce midi instrument parts quite quick.
It will still bounce in real time though. 1. Select the the region(s) you want to bounce and solo the track. 2. Press Apple+alt+B to bring up bounce window. 3. Select correct format. (Multiple mono if you bouncing a stereo instrument.) And also the bit and sample rate you working with. 4. Tick the box "import after bounce" 5. Click bounce and name the file (it will be saved in the audio files folder by default. 6. Click save and it will start bounce. 7. After that you will be asked if you want to import the bounced track to a new track or to the region list. Select new track and select "selection" from the drop menu. 8. Click ok and pro tools will create a new audio track with your bounce and put it it the right place where you made the selection. 9. Make the bounced instrument track inactive and hide it if you want. Its quite quick ![]() |
If you are using multi output's VI's you can see that the VI multi output appears in the INPUT of an audio track.
Just create a audio track for each Multi-output you have conf, if you have input monitoring thats great, you can listen right away without recording, if not just record it. any change you make just punch in/out that part and voilá the changed part is in place. When you don't need to the VI anymore, just disable the track and hide it and use the audio track for mixing. regards, Marco
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
Cool, thanks for the responses guys (and girls ? :-D ) I'll try it this weekend. Having serious stability issues on Windows 7 x64 at the moment...
![]() Quote:
Its not "quite quick" if your instrument plays throughout a 4 minute song. State of PT for this kind of thing is ridiculous in 2011. |
V8 Next Week | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 12-10-2008 05:36 AM |
OT - Anyone going to AES next week? | soundsurfr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 10-19-2003 06:02 AM |
AES NY next week end | The Ram | Pro Tools TDM Systems (Mac) | 0 | 10-02-2003 09:46 PM |
Next week or so | Lalaman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-21-2002 01:41 PM |
One week with the 001 | geojack62 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-26-2001 03:14 PM |
