editpack track select gives "No Valid Tracks"???
Ever since upgrading to Pro Tools 8, the track select button on our edit packs doesn't always work. Most of the time it does not. Sometimes I boot up a session and it works for a few hours and then stops working, which leads me to think it is something I'm doing.
When it doesn't work, the displays read "No Valid Tracks". Turning the knob won't allow me to select other tracks. It also renders the second panner useless when I'm trying to assign that to a mono track. This is really slowing us down when we are mixing FX. We've called Digidesign and they claimed to have never heard of it. They want us to reset the firmware but I haven't had time. Anyone else solved this problem yet? Matt |
Re: editpack track select gives "No Valid Tracks"???
i figured it out.
if you bank or nudge the faders so that there is no track in the leftmost channel, then you will get the No Valid Tracks message. As a workaround, if you move one of tracks' position in the Edit Window, the functionality returns. |
Why send tracks to hardware outputs instead of "Master" track/bus? | gopher | Getting Started | 11 | 01-03-2014 12:12 PM |
Directing all tracks to a "master" track? (Just arrived from Logic Pro land!) | yeloop | Pro Tools 11 | 2 | 12-21-2013 09:31 PM |
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
PT8--Track labels "smear" when re-ordering tracks | bashville | Pro Tools TDM Systems (Mac) | 1 | 01-10-2009 08:22 AM |
How to blend "three" separate audio tracks onto one track..? | Sabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-31-2002 08:46 AM |
