PT10 on Windows 7 ?
Hi I was curious to see what experiences people have had with running Pro Tools 10 on Windows 7. Is it stable? As good as running it on OSX? I have a IBM thinkpad with a 1.83ghz core duo processor and 3 gigs of ram with Windows 7 and was wondering if I would be able to run it on my comp if I wasn't going to be using many plugins. Please advise...
Re: PT10 on Windows 7 ?
An IBM Thinkpad is probably not compatible, considering IBM sold their PC division to Lenovo at least 5 years ago. 3GB of RAM is marginal for Win 7, although a 32 bit OS can only address a little less than 4GB.
If you look at the Avid requirements for PT 10 you will see they want a lot more. However, they have a 30 day trial version available and you can get that and see how it runs. You will need an iLok USB key as it's required by PT for the product key. Click Me
PT MP9/Sonar X1 Ozone 5 Member of Nashville R.O.P.E. Assn. |
Well, it's pretty and it works nicely when you aren't doing anything serious. Once you really start doing hardcore work with tracks and plugins and everything else....it'll give you a memory error before you are done working, and you'll have to reboot. Not the worst thing in the world, but worth mentioning.
Mostly, it's when you go to save your work, you will get an error like this one that I took a screenshot of: https://lh6.googleusercontent.com/-Z...oughmemory.png Or you will suddenly get insanity like this, after telling you that it could not save while translating tracks or something: https://lh5.googleusercontent.com/-U...ingupagain.png Look at the screen there. That's what happens when you do a lot of cuts/fades/crossfades and have saved 100 times already. Sooner or later, you won't be able to save and will get this instead. It's as if the programmers made it so that every time you save, the 1+MB saved project file somehow takes up your memory and stays there until you reboot or something. Other than the memory leak or bug, it's great. I really do love PT10, albeit frustrating love. ;-) |
I rebooted, re-opened my project just a few minutes ago and continued working. I got about 5 minutes of work done before it did this again:
https://lh6.googleusercontent.com/-6...uldnotsave.png Then I rebooted, opened the project and got this after a single edit and save attempt: https://lh4.googleusercontent.com/-E...ntimeerror.png Would love to know of a way to work around this. |
Update: I uninstalled PT10 and then manually deleted all the left over folders (including my plugin directory). I re-installed the program plus all my plugins and everything is working fine for now. When I save, it saves a lot faster than before.
It may run with those specs, but it may choke quickly too. 3 gigs of ram is very low and the dual processor wont give you much power. |
'what EA said'.. Ur bound to hav a lot of hang ups running W7 which is gonna take up over 1 gig alone.. Longer it runs, the more ram W7 is gonna start eating. "& then there's PT"
3gig.. Not enough for a real session.. Maybe a few tracks & plugs but thatz about it... Sent from EPIC 4G using Tapatalk On'eim...
PT 10 on my WIN 7 works great
Wow am I groovy or what |
Hi, i'm disapointed to see that this problem is still there with PT 10 !
I have it since WinXP and PT8. I'm now on W7 with PT8.05 and it seems to be a bigger problem than ever. But i suspect for a long time my UAD card for this problem and i see on the pictures that you have it too... I need to stay for now on 5.8 software on uad because of latency, but you, are you up to date with UAD, PT10 and W7 ? |
It seems definitly to be a problem linked to UAD.
http://www.studionu.com/uadforums/vi...131231#p131231 |
PT10 Windows 7 64 bit vs 32 bit | BSykesBeatsFool! | Windows | 6 | 02-02-2013 07:12 AM |
Windows 8 and PT10.2 | txshonk | Windows | 22 | 12-30-2012 12:31 AM |
PT10 in a Windows 7 lab situation | TallNorton | Windows | 6 | 08-22-2012 10:24 AM |
PT10 & Windows 8 RTM | michaelmcg92 | Windows | 2 | 08-21-2012 07:21 PM |
Windows 7 won't shut down after using PT10 | britune | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-02-2012 03:03 PM |
