I really hope someone can help me with this... I would like to know if protools m-powered will work on the following laptop...? Dell Inspiron 15 Intel® Pentium® Dual-Core Processor T4200 (2.0GHz, 800MHz, 1MB cache) Intel® Cantiga GM45 Chipset Windows Vista® Home Basic SP1 32-Bit 2048MB 800MHz Dual Channel DDR2 SDRAM Thank you very much for your help. I have spent hours searching through forums and the pro tools website but it is quite hard to get a clear answer. Regards, Conor |
Start here and post a Sandra report;
http://duc.digidesign.com/showthread.php?t=193637 http://duc.digidesign.com/showthread.php?t=133039
~ tom thomas Formerly hobotom Pro Tools Ultimate 2022 HDX Hybrid HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
Hi Tom,
Thanks very much for your reply. This is a laptop I am considering buying... therefor I can not provide a Sandra report. Any pro tools users have experience with this laptop? Thanks, Conor |
Hi Conor,
Did you get the Dell? If so did it work? I'm looking at the same or similar laptop for my M Box 2. Please let me know. Like you I've spent ages researching, but can't get a clear answer. Thanks, Fridbin. |
Dells have been a little sketchy with Pro Tools mostly because of firewire compatibility. Some users are fine with them… Other are hating life.
I’m not sure there is a good clean answer for you.
Thanks Tom
Re. the Firewire issue , is there something in particular to look out for/avoid? Fridbin |
Digidesign recommend Texas Instrument chipset.
Also, from what I have experienced, onboard firewire controllers have many quality/noise-related issues. Of course it depends of the motherboard and the components. In practice, audio interfaces are not powered by 4-pin firewire connectors so it reduce "internal noise issues related to IRQ channels". |
What he said, The TI chipset and the F/W drive should have the Oxford 911 or better bridge.
This laptop will probably have a Ricoh firewire controller. Used to be a bad thing, but I am using a Dell laptop with a Ricoh controller right now and I have no problems in this regard. I am using PT8 with the M-Audio 1814 Firewire audio interface.
Laptop Dell Inspiron R14 & Protools 10.3.2 | RChilian | Windows | 1 | 04-08-2013 08:42 PM |
using 7.4 with a dell inspiron 600m laptop | normanvegan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-26-2008 03:09 PM |
Laptop for Max Results-Dell Inspiron 9400 ok? | visualvideo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-25-2007 11:20 PM |
dell inspiron 8600 laptop | niros | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-06-2004 09:13 AM |
M-Box with Dell Inspiron laptop-any success? | steve at Your Heaven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-17-2003 11:49 PM |
