GPU cores on MacStudio matter?
Hi there,
Is the GPU cores number important ordering a new Mac Studio Ultra to work with an HDX system? Maybe some plug-in or protools itself is using GPU? Thank you for your help |
Re: GPU cores on MacStudio matter?
For me, the Mac Studio would be a bit of a waste, as I deal mainly with music and not video. I wish there was a version 24 CPU and 10GPU and then I'd buy.
Personally I am hoping there will be a Mac mini with an M2 Pro chip. "Studio" is a bit misleading in terms of music, as all those GPUs are for video guys.
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3 |
Unless, of course, Avid comes up with a clever way to offload plugin processing to GPU.
Unlikely though, because maintaining cross compatibility between Mac and Win has been too important lately. To do it with a known quantity (Mac) needs some serious coding, but to do it with a wildcard system (Win) is a whole different ballgame.
Mac Studio max base unit with 3-displays (24”-32”2k-24”-1080)
Was almost on par with my MacVideoCards efi Radion 580 Using OWC TB to dual HDMI and built in HDMI FOR THE 2k display. I would say GPU does matter IMO. Also largest internal drive!
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Thank you for your advice and yes, a large internal disk it’s a great option!
Studio is much much more than GPU. Mini is good for what it is, but it is limited in i/o ports. Even with greatest CPU it would still be crippled. VERY capable though, but you need to be okay with one HDMI, two USB-A and two thunderbolts. Mine is fully loaded (incl. 10gbps ethernet) and love it, but every single i/o is already used so there is nowhere to go when things get heated.
Agreed on the ports, as I run two screens and have to use one of the Thunderbolts for that. The mini was my cheap entry to Silicon Macs while I decided what to do. I just can't bring myself to spend big on so many GPU cores with the Studio.
If they upgrade the top line Mini chassis with those 4 Thunderbolt ports from Intel to an M2 Pro and 32GB RAM, I'd be more than happy for music use.
Of course you know this, but you don't have to 'waste' a TB port just for a second display. One of my TB ports has a dock with HDMI, ethernet, one TB, and lots of other ports.
In short, no, at least not currently. I went with the first tier Studio Ultra and its video capabilities are insane. PT won't even need a fraction of what the GPUs are capable of.
Thank you again.
new mac.... macpro trashcan vs MacStudio M1Max | studiomac | macOS | 6 | 08-15-2022 07:47 AM |
MacStudio HD Nativ | chaos audio | Pro Tools HDX & HD Native Systems (Mac) | 7 | 04-13-2022 06:17 PM |
Upgrading 8 Cores To 12 Cores | Logichead | Pro Tools TDM Systems (Mac) | 2 | 10-10-2015 11:32 PM |
Problems when using all 4 cores vs. 3 cores | hopelessennui | macOS | 1 | 02-03-2012 06:54 AM |
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores | Hive Guy | macOS | 8 | 05-10-2011 11:05 PM |
