Trouble Setting up Midi
Just got the PT Mbox setup and installed everything.
I am able to hear the LE demo song that comes with it so I think all audio stuff is working OK. I am unable to get PT to recognize any midi input. The manual is not very helpful with getting midi connections working. All midi stuff worked fine in Logic 6 Any help would be greatly appreciated. I have: Panther 10.3.3 G4 768mb of RAM Pro Tools LE 6.2.3 Mbox (Connected directly to USB) m-audio midi connector 2x2 (connected to USB hub) |
Re: Trouble Setting up Midi
1. Have you created a studio setup in the Audio Midi set up application? If not, the application is located in the Utilities folder.
2. Certain USB hubs are known to have issues with midi interfaces when used with PT. Make sure it is compatible by checking the compatibility documents at the Digidesign support section of their site. 3. After checking the above and you are sure all your software & hardware is compatible (including third party applications that may be running in the background). Open a session and go to -> Midi Menu -> Input Devices - and make sure that you check off the appropriate boxes. 4. Go HERE for additional trouble-shooting. dk -----------— Dual 1.25GHz FW800 / 512MB ram OS10.3.3 Panther PTLE 6.4 - DIGI 001 100GB OWC Firewire Audio HD DigTranslator 2 McDSP Analog Channel Waves 4 - Native Power Pack
www.dpksound.com |
Found this quote on the Digidesign Answer Base:
"Mbox is designed to work on a single, dedicated USB port build into your computer. We do not support its use on any hubs, adapters, expansion cards, or the USB port on the side of your USB keyboard" dk
www.dpksound.com |
Hey,
Thanks for helping out. I have looked through the Reference guide and what I have not figured out is whether there is: 1. A problem with OSX seeing the m-audio midi interface 2. Whether there is a problem with my midi setup inside of Panther. 3. If there is a midi setup problem inside of PT. |
There doesn't seem to be a problem with the Mbox
audio. It is connected directly to a USB port on the computer, not a port on the hub and seems to be working fine. I will try to connect the midi interface directly to a USB port and see if that helps. THanks |
Hey,
In the Audio Midi setup application I have 3 things. The m-audio 2x2 icon the icon for the Apple IAC Driver An icon with a ? mark on it that says it is "Digidesign" in the info panel. Am I missing something in here? Thanks fuzzy |
Seems like I have a similar kind of problem. I-book 600 MHz, Dual USB, firewire, 640RAM, Digirack 002, Panther 10.3.3 and Pro Tools 6.4 Can't get midi signal in my software. Keyboard connected into the interface, Audio Midi Setup OK, tested - works. DIGI 002 also blinks (gets signal from the keyboard, but Pro Tools MIDI track won't respond. I already checked the Input device, also activated Record button. What am I missing? Any help appreciated. Thanks Everybody. Raul
PTLE 7.4.2 Digi 002 Rack MacBook Pro 4,1; 4GB RAM OS 10.5.8 |
I also am having exactly the same problem. I started a couple of threads but they didn't go anywhere.
Having followed all the instructions for setups, the only thing left is for PT to do what it's supposed to, which it does not. and what's up with AMS continually detecting an extra input device? I wire up my novation and get that set up on the screen, only to have a new [?] device appear when i check back. I'm sure many of us would appreciate some feedback from digi about this. Who else has this problem?
Ibook G3 800 640MB OSX 10.2.6 PTLE 6.1.1 Mbox |
bump.
Trouble setting up a template... | Rayvenx2208 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-11-2010 11:17 PM |
trouble setting up equipment!!! | 59chaz | Pro Tools M-Powered (Win) | 1 | 08-18-2010 03:01 AM |
trouble when setting MIDI banks | march | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-19-2006 05:58 AM |
Trouble setting up Korg Triton as MIDI controller | Rumeal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-27-2004 09:00 AM |
Trouble Setting Up Midi Controller | u4s | MIDI | 1 | 02-09-2001 11:49 AM |
