HDIO WC issue in latest PT2020 - MTRX
A recent update in protools and DADMan has seemed to have put my HDIO into a bad place. Essentially I cannot get it to clock so I get oscillating drop outs at varied rates depending on what clock source is selected.
I have a fairly complex setup with a MTRX, Burl B80, HDIO, Waves DLS. These all get WC from a OCXHD. I noticed new options for the MTRX in both DADMan and PT. IE, in setup you can now select MTRX as the sync source in PT. There is now a DLY option in DadMon that seems to set itself to 5 no matter what I do. I have tried every config I can think of and the closest I have gotten to where the HDIO seems to sync is with the DLS off. When I start PT it will not sync. I go to settings and select the HDIO WC as source and it works, then I go and reset to MTRX and it continues to work as long as the session is up and running. The system was working fine until some recent update. I don't always use the HDIO so may not have noticed it when it really started. MTRX is set to WC in, Pri/Pri, Adapt to Digilink1, 75ohm term Session is at 96K, have not tried any others yet. Any thoughts? HDX2 Mac Trashcan S6 |
Re: HDIO WC issue in latest PT2020 - MTRX
Hey, so I'm having new sync issues after I updated my system from MacPro 5,1 > 7,1, fresh install, Catalina etc. I changed my interface combination from a 192 + HD I/O 16x16, to an OMNI + the HD I/O 16x16 (i.e. replaced the 192). Interfaces are synced with Loop sync.
Likely its unrelated, as we've completely different interface setups, but worth throwing up here, as clearly something sync related is not working. I mix music and regularly use hardware in parallel on my master bus (use 2 Auxes, one with the HW inserted). Since the hardware/software update, I've been having constant issues with the clocking / delay compensation with the HW insert delay compensation being calculated incorrectly. Sometimes it can be corrected with a change of 1 sample on one of the master Auxes, other times, the 1 sample won't work and I need to constantly change the Loop sync clock source from each interface until it sounds correct. Sometimes it never does and a full restart is required, but that just ends up with another random sync issue Two days ago I changed out the OMNI for the 192 and haven't had any of the issues, yet. Lots of moving parts here so need more time to isolate what the issue is. Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2 |
I hope someone from Avid can chime in as it was working perfectly before. |
Also the Digi Dly setting has nothing to do with the clocking so it certainly has nothing to do with your problems.
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
Projects issue in PT2020 | tamaman67 | Pro Tools 2020 | 0 | 04-20-2020 10:35 AM |
MTRX connection issue | DHS | Pro Tools | MTRX & MTRX Studio | 18 | 12-16-2019 01:17 PM |
MTRX activation issue | DHS | Pro Tools | MTRX & MTRX Studio | 5 | 11-14-2019 08:40 PM |
Issue with latest Mac OSX updates???? | jyork | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-22-2009 08:44 AM |
Latest Pro Tools 7.1 cs9 DAE issue | robopat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-09-2006 12:22 PM |
