Old 07-10-2015, 07:04 PM
KierONeil KierONeil is offline
Default How to decouple MIDI from Time
I pulled down some classical music and have made the different themes I wanted as separate MIDI files.
Unfortunately, Whenever I put them into an instrument track the clips start where they would in the original score. I want it to act more like an audio clip that I can move around to different parts of the composition and to different instruments.
It there a way to do this without printing them to audio files?
Pro tools 12
Windows 8
Dell Laptop
Old 07-10-2015, 08:07 PM
Default Re: How to decouple MIDI from Time
Nevermind, I found using the Trim tool in the edit window did the trick.
Old 07-11-2015, 04:39 AM
Stig Eliassen's Avatar
You can drag MIDI clips around with the Grabber tool.
Old 07-11-2015, 04:59 AM
Glenjb Glenjb is offline
Use slip mode or hold the ctrl key (cmd on Mac) while in grid mode and it will behave like slip mode when you move the clip.
Midi is played on time but midi notes are early on play back. steveooo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 09-30-2022 12:17 PM
double time or halfe time some midi in PT???? metaltim MIDI 10 05-21-2013 03:10 PM
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
How to Double Time (or Time Stretch) Midi? noharmlessrock MIDI 4 04-02-2008 07:32 PM
is there latency when using midi time code or midi clock(im still new at this) Cali Hendrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-15-2003 10:18 AM
