Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-16-2022, 09:02 AM
JR Fountain JR Fountain is offline
Default MTRX Studio Mic In's / Dolby Audio Bridge...
Hey there,
I'm a sound designer and run Dolby Atmos in my studio. Often while I'm cutting I need to record sound effects. Unfortunately one of the limitations with Atmos in PT is that I don't have direct access to the MTRX Studio mic inputs because I have to use the Dolby Audio Bridge as my playback engine.
Currently solution is simply to record separately to my field recorder and then transfer the recording over to the computer via SD card. I feel like there's gotta be a workaround to use the MTRX Studio Mic in to get the sound into another piece of software like Garageband to at least avoid swapping the SD card constantly. I thought Dante could be my friend here but so far no luck.
Any ideas?
Thx!
J.R.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 09-16-2022, 12:46 PM
Reckless Erik Reckless Erik is offline
Default Re: MTRX Studio Mic In's / Dolby Audio Bridge...
You may need to create an aggregate with Dante and the DAB and route the mic inputs into Dante via the matrix. From there into PT! Big PIA!.
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 09-16-2022, 12:51 PM
creativecontrol's Avatar
Good things are coming!
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-16-2022, 04:11 PM
LDS LDS is offline
GASP! 2022.9?
If you usually use digilink and don't need more than 64 inputs into the renderer, you could tie your MTRX Studio to the renderer using DVS.
Another option that I regularly use when just editing, etc, is to just use the digilink hardware in Pro Tools.
- Disable Atmos under peripherals
- Under the bus tab of the I/O menu, send all of your beds to the first available physical 7.1.2 output. That output then becomes your monitor out
- Then in your session, just tap the obj/bus toggle on your object tracks (select all and hold cmd to do it to everything).
All your routing, panning, etc stays intact, it makes recording the same as any other Pro Tools session, and it only takes a few moments to revert back to using the renderer when it is required.
I am looking forward to the day the renderer gets integrated into Pro Tools.
Old 09-19-2022, 06:23 AM
I was hoping you'd chime in with something to this effect Jeff. Good to hear!
Thanks for the other suggestions guys, seems like 6 of one, half a dozen of the other so I think I'll stick to my low tech solution for now since I'm used to it.
J.R.
J.R. Fountain
Old 09-20-2022, 02:34 PM
Well Jeff, exactly how long do we have to wait? Until the coke is warm and the popcorn is cold?
[email protected]
Newcomer Audio Post
Old 09-20-2022, 03:28 PM
..or in my case, iced green tea with warm chili garlic edamame.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-21-2022, 01:59 AM
nedd nedd is offline
...I saw it on IBC last weekend...it's almost here...
___
Mac Studio Ultra, OS 13.6.5 MTRX Studio, PT Ultimate 2023.12.1, HDX1, Sync HD, BM Decklink Extreme 4K, Genelec's 9.1.4, Dolby Atmos Renderer, Avid Dock, S1, SoundFlow, Streamdeck
Old 09-22-2022, 01:28 PM
Classy stuff Jeff. I now know what my subscription pays for! Hehe.
[email protected]
Newcomer Audio Post
Old 09-28-2022, 11:50 AM
AUX IO in Pro Tools 2022.9 - in combination with DAPS, Bridge and HDX:
https://youtu.be/ZdM3HsHuozQ
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX Studio HDX and Dolby Atmos Production Suite Goombot Pro Tools | MTRX & MTRX Studio 64 09-30-2021 01:02 AM
What brings Dolby Audio Bridge to HDX users? nedd Post - Surround - Video 29 01-03-2020 03:24 PM
Dolby Audio Bridge and AVB RSLAMBERT Avid S1, S3, Dock and Control App 0 11-03-2019 01:46 PM
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig bsteeve Post - Surround - Video 3 08-16-2019 06:19 AM
