Old 09-17-2003, 02:51 PM
Giles Giles is offline
Default Reached logical end of file -39
Bouncing to disk has been failing for us 50% of the time here. We have no issues if we bus the tracks out, but bouncing will result in an error that states "Could not complete the bounce because logical end of file was reached -39" The bounce goes all the way through, but will not write the file at the end.
Has anyone else seen this? It is an HD/TDM system runing OSX.
Thank You,
Giles Christenson
Old 09-17-2003, 03:07 PM
urumita urumita is offline
Default Re: Reached logical end of file -39
try to make a selection and bounce only that selection, there's usually a dialog box when you choose bounce. Make a selection, name it save it and reselect it before you choose bounce to disk. I usually make it 1.5 times longer than the RT60 on my longest reverb after the end of my fade, if I fade, so as to not make any clicking noises when it cuts off the bounce.
love and light
Old 09-17-2003, 04:01 PM
Thanks for the response, That is our normal way of working as well. most of the time it works, sometimes it just doesn't though.
Old 09-18-2003, 07:54 AM
I forgot to mention:
This happens on multiple drives, on multiple projects. The machine is a dual 1.42ghz G4.
Old 09-18-2003, 08:28 AM
Russ M. Russ M. is offline
Are you running mixed drives, ie; SCSI, FIREWIRE & IDE? If you're running a session on SCSI or other, bounce to the same type Drive, SCSI or whatever.
Mac Pro: 3,1, 8 core, 6GB RAM. OS 10.6.8, Protools 10.3.8 TDM HD2 Accel.
SD2 file reached logical end? jackjamesdrums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-02-2012 02:40 AM
Logical End of File Reached -39. DigiDigiDigi-cant-u-C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-27-2010 12:16 AM
Logical End-OF-File reached (-39) destudio Pro Tools TDM Systems (Mac) 2 12-28-2005 09:42 AM
Logical end of file reached (-39) ???? Eng. Def Jeff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-14-2005 03:49 PM
Logical end-of-file reached (-39) yeshe337 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-06-2003 09:13 AM
