Installing PT10 on Esata drive
I generally use PT10 on my home PC (Windows 7). I am on the road quite a bit for work and have a work laptop which I would start to like to use to do some editing when I am away. Although there is no policy at work that says I can't install other software, I'd rather not have PT10 blatantly on the laptop, and don't want to give any extra headaches to IT. So my question is, has anyone tried installing PT on an ESATA drive? I've read about people using ESATA for their audio files but not actually installing on the drive. If not one has tried, any conjecture on whether it could work? I don't want to invest in one unless there's a good chance it will do the trick. I'd use a separate USB drive for audio files (since I would assume if the ESATA drive does work, I should still follow the rule of not having PT and audio files on the same drive). thanks, any advice would help. I could just buy a new laptop I suppose but then would be carrying around two laptops at the airport - doesn't sound like much fun. |
Re: Installing PT10 on Esata drive
I doubt there'd be an issue, eSATA is pretty much the same as normal internal SATA. However, keep in mind that installing a program isn't only about where the files are stored. Programs put registry keys and shared DLL's all through your computer too.
Joel |
You are supposed to install Pro Tools on the C: drive, and you really need to follow that advice. You could possibly make the eSATA drive bootable and do it that way. But that might need you to purchase another copy of Windows (depends if you can clone the current disk or not and where else you might want to boot/run that drive). You could then record to the internal drive if it's up to spec, and you do not mind having the files on that drive. Seems like a lot of hassle. You sure you cannot just install PT on the work laptop?
Installing Pro Tools on other than the system drive has led to problems and is not recommended nor supported.
ok thanks all it does sound like a hassle. I think I will just install on the work laptop.
Mac Drive + Esata = use caution | browniespeaks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2011 05:38 AM |
Mbox2 Pro recording to eSATA drive? | trupro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-07-2010 10:09 AM |
esata drive question | pigdig | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-26-2009 12:08 PM |
eSATA Drive Question | AirborneFO | Storage Subsystems | 1 | 06-05-2009 02:06 PM |
Anyone using an eSATA drive with Firewire. | michael c | Pro Tools TDM Systems (Mac) | 1 | 09-27-2006 09:22 AM |
