D-verb and other reverb plugins
Hello,
I can't decide if I like the D-verb that comes with PTLE. Any thoughts on this topic? Has anyone used other reverb plugins with PTLE for windows? Which ones? Where did you get them and how much did they cost? Thanks for any input you can give me! William Hayes
~WH~ |
Re: D-verb and other reverb plugins
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by saxbill:
Hello, I can't decide if I like the D-verb that comes with PTLE. Any thoughts on this topic? Has anyone used other reverb plugins with PTLE for windows? Which ones? Where did you get them and how much did they cost? Thanks for any input you can give me! William Hayes<HR></BLOCKQUOTE> I and many others that frequent this forum don't particularly like DVERB. You can get others from 3rd party vendors that sound much better but I understand they are real processor hogs. What many do is use an external reverb on an insert. Even my old Midiverb works better for me. My advice, use an external one and save your processor for other things. |
I would be interested in someone that has used it successfuly maybe posting their settings. Every time I use it is makes the vocal hiss too much. It also makes the vocal sound very dark and lifeless.
Hello, anyone out like D-Verb?
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
I got it to sound allright using the predelay cranked way up and cranking the mix way down and adjusting the the delay rate to a reasonable delay time. I dont like really wet reverb sounds.You just have to play with it.Try doubling your vocal tracks that usually brings more life to them.Have fun Stu
Hi, yes I have actually used d-verb with reasonable success. And at itmes I quite like it. It does take a little bit of getting used to though.
Try using a send (second group of five under the inserts on the channel strip) via a buss to an aux track (with d-verb as an insert on this aux track). Ride the fader on the aux track to add the amount of wet signal you may wish. Try using some of the presets in d-verb to begin with but then try increasing or decreasing decay, pre-delay etc. (I use 100%mix and 0db input levels mostly.) It took me a bit of time to get to get good results but it is actually very useful. Then again, I'm mainly doing acoustic/classical/ambient/chamber stuff. If you do a search on the DUC, there have been some interesting discussions on this. There are some folk who think d-verb is excellent. Maybe email them for suggestions. Cheers, Haigbabe
Drive fast, take chances |
Here are my two favorite D-Verb settings. The first is my "Room" setting. I'll put this verb on a stereo aux, and buss all tracks to it, setting the overall "wetness" of the mix with the aux fader. Makes it sound as if everything happened in the same room, at the same time. The second is my "Ambience" verb. I usually use this one to fatten up a vocal track. Not too much, very subtle. I also put this verb on an aux and set the wetness with the aux fader. I never use reverb as an insert on any audio track, always bussed to an aux.
Room Verb Input Level = 0.0 dB Mix = 100 % Algorithm = Room 2 Size = Small Diffusion = 87 % Decay = 708 ms Pre-Delay = 21 ms Hi Freq Cut = 20.00 kHz LP Filter = 7.92 kHz Ambient Verb Input Level = 0.0 dB Mix = 100 % Algorithm = Ambient Size = Small Diffusion = 87 % Decay = 447 ms Pre-Delay = 0 ms Hi Freq Cut = 11.12 kHz LP Filter = 9.52 kHz [img]images/icons/cool.gif[/img] Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
Rob Papen reverb RP-Verb | crizdee | Pro Tools TDM Systems (Mac) | 7 | 09-02-2009 11:11 PM |
Are there any other reverb plug-ins besides D-Verb | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-26-2006 09:45 AM |
D-Verb reverb panning not as wide using aux bus | ou812 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-17-2005 06:49 AM |
Ren Reverb:Real Verb Ratio | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-30-2001 07:59 AM |
D-Verb vs. TC|Works reverb | pita | Digidesign Hardware & Software | 2 | 12-15-2000 04:06 PM |
