Mic gain level setting with Mbox 3rd gen
Hey guys I have a quick question. I have an Mbox 3rd gen and currently I will be using it to record vocals with my mic. I just have the standard condenser mic that needs phantom. Anyway, is there like a general rule of thumb when setting levels for mic gain? like should you not go past the halfway mark, or stop at a certain meter color or what? I mean I know not do record anything in the red but I would just like advice on how to fine tune gain settings to get the best vocal sound.
Re: Mic gain level setting with Mbox 3rd gen
Personally, I record with peaks around -6 dB.
Cheers,
Is that just using the microphones regular settings, or do you have a -db switch turned on the mic itself?
That's setting the gain on the incoming mic signal so that the signal peaks at -6dB.
Cheers,
MBOX MINI 3rd gen Clipping even with gain set at lowest level | Drapte | FireWire & USB Audio Interfaces (Win) | 2 | 05-25-2015 06:22 AM |
Gain, level on preamp vs gain on Digi (guidelines)? | rcook349 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-04-2007 08:18 PM |
outboard pre into Mbox; setting "unity gain"? | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-11-2006 06:43 PM |
using outboard pre w/mbox - gain knob setting? | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-11-2005 09:35 AM |
Mbox Input level only half w/ full gain recording | mgfan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-05-2005 02:38 PM |
