is there an equivalent of Cubase "arranger" in Protools 8
I have just upgraded to Pro Tools HD 8. Over the years I cave used S Lab Notator and then Cubase . Both of these systems had a very useful facility that was "arranger" where you could work on individual sections of a song, then chain them together in whatever order you chose to get the arrangement. Ive look all over Pro Tools and cant find the equivalent facility. Am i just looking in the wrong place, ie is it called something else in Pro tools, or does the facility not exist in Pro Tools. Assistance required please |
Re: is there an equivalent of Cubase "arranger" in Protools 8
PT has no equivalent to this
you can do this by copy/drag or copy/paste
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
When I need to do this, I use REGION GROUPS. RTFM.
--Jeremy |
You'll probably want to look at Region Groups (a way to temporarily consolidate regions into sections) and then Shuffle Mode. It will work just as Cubase although may require a little bit of setup and change in habits.
Thanks Guys, much appreciated.
or save a selection (song-section) as a memory location
Region Groups. Keep in mind for shifting tempos Have your midi and audio in Sample-Base and duplicate or add new tracks for each section.
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" | xfarre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2011 07:37 AM |
plug-in equivalent to spx "symphonic" preset? | travista00 | Pro Tools TDM Systems (Mac) | 0 | 07-22-2008 10:47 PM |
PT 6 equivalent of LA 6 "freeze" function? | Carder | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-26-2003 08:29 AM |
why isn't there a midi "touch tracks" equivalent for Protools | fathermac101 | Pro Tools TDM Systems (Mac) | 9 | 04-07-2003 01:30 PM |
Looking for "Write to All Enabled Parameters" LE equivalent | CCash | Pro Tools TDM Systems (Mac) | 1 | 05-15-2002 05:39 PM |
