Old 08-27-2009, 04:26 PM
RichrdC RichrdC is offline
Default Plug-Ins using tons of CPU
A thought occurs to me from reading some other posts.. It was mentioned that the spiking of CPU power use can happen because of plug-ins not having the most current drivers installed.. My question is, if after you've installed the most current drivers, are all of that particular plug-in's instances across many different sessions then updated, or do you need to save all the sessions without that plug-in, and then re-insert it again and save it so the newest drivers are in use?
8.0.3 = Tons of Static imloggedin Pro Tools TDM Systems (Win) 44 02-06-2010 01:34 PM
Amplitube Using Tons of CPU RichrdC Pro Tools M-Powered (Win) 11 08-16-2009 07:53 PM
Tons and Tons of Outboard Gear TommyComa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 06-18-2007 11:43 AM
6.9 using up TONS of CPU Produce_Dept 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-25-2005 06:48 AM
tons of questions for you all fuelie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 02:22 PM
