Re: Tons and Tons of Outboard Gear
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Good advice he would be wise to take it
brandy |
I'll admit I haven't heard some of the gear you've mentioned, but the only piece I'd use as an insert would be the Eventide H4000. That's a heavy-duty effects unit capable of craziness. Otherwise, I'd stay in the box while mixing. The plugs you mentioned are high-quality.
The compressors, however, you might just want to use them while tracking, say, vocals, acoustic guitar, bass, piano, etc. So, having external preamps with insert jacks makes sense here. Presonus Digimax, maybe? Then, when you want to track with a compressor, you'd just have to connect it to the insert jacks. Without insert jacks, you'd connect them (obviously) to the line-output of the mic pre and in line-input of the 001. Not as quick as a patchbay, but not bad, considering you'll only be changing things when it's time to record a different source. Patchbays and insert jacks aside, you could just simply set it up for your most often-used signal chains. For example, 001 inputs 1 and 2 could have the Avalon in the chain, 3 thru 5 have no hardware connected, 6 could have the Manley, and 7 and 8 could have the Eventide (which could also be connected to 001 outputs 7 and 8). Also, the Avalon compressor has a built-in bypass, so it's just a button-push away. By the way, why do you need all 18 inputs at once? Set up as above, if you had external mic pres for all available inputs, you'd have 16 inputs always available. Are you multi-tracking live bands quite regularly?
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
Thanks for the help guys...Iv got it all set up and sounding great! Setting up the patchbay was alot easier than expected...yes i do agree the eventide is awesome. Thanks again for all of the advice, And yes I do alot of multi tracking...lots of live bands. and I never mix outside of the box, I just wanted to explore some new routes with external effects. Thanks again guys.
-Tom |
8.0.3 = Tons of Static | imloggedin | Pro Tools TDM Systems (Win) | 44 | 02-06-2010 01:34 PM |
Plug-Ins using tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 0 | 08-27-2009 04:26 PM |
Amplitube Using Tons of CPU | RichrdC | Pro Tools M-Powered (Win) | 11 | 08-16-2009 07:53 PM |
6.9 using up TONS of CPU | Produce_Dept | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 04-25-2005 06:48 AM |
tons of questions for you all | fuelie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-26-2002 02:22 PM |
