Pro Tools M-Powered 7.1.1 for Intel-based Macs
Pro Tools M-Powered 7.1.1 for Intel-based Macs is now available for download:
Pro Tools M-Powered 7.1.1 is a free download for all Pro Tools M-Powered owners with M-Powered iLok authorization. Pro Tools M-Powered 7.1.1 Downloads
For Pro Tools LE 7.1.1 and Pro Tools M-Powered 7.1.1 for Intel-based Macs Please see the additional download pages there for separate installers for documentation, optional plug-ins, optional software, and software bundles not included with the main Pro Tools M-Powered application download.
Administrator Avid Pro Audio Community |
Re: Pro Tools M-Powered 7.1.1 for Intel-based Macs
Hello
I have a iMac Intel core duo OSX Tiger 10.4.6 , and my old plugin wont work with PT 7.1.1 Mpowered Waves 5.2 wont work and the Waves7 updater wont work too! URS wont work! Oxford wont work! Serato wont work! Bombfactory wont work , only free bombfactory working! And I had problems with palyback and record I have 1 HD Sata with 2 partitions (system , audio) 1 HFS journaled (first partition) and 1 HFS journaled (second partition) When i try to record or play at the 2 partition i get -9131 ERROR If i try with the first partition (system) i do not get ERROR can someone help ? thanks Andre Mattos Record Engineer |
All plug-ins and software have to be updated for Intel-based Macs, unless they were already updated to Universal Binaries for PPC & Intel-based Macs.
All of the Bomb Factory plug-ins have been updated for compatibility with Pro Tools 7.1.1: www.digidesign.com/compato/osxintel/ma/sw.cfm But you need to download and install the updated versions from the optional software page linked from the main Pro Tools 7.1.1 page: www.digidesign.com/download/711/sw As far as I know, none of the other plug-ins that you mentioned are compatible yet with Intel-based Macs.
Hi admin
Can I just say again that this update has been the best and on time I seen from digi yet. I use a top of the range imac intel and its unbelievable so far .Solid as arock in every aspect. great work. brandy |
I have the same issue, the only plugins that show up are the ones that were inlcuded w/ PTMP. I have RTAS Plug ins that will say they are loading on the PTMP load screen and won't show up in PTMP..they have all been used before with my other DAW (Nuendo and DP5). I even re installed the plugins like Komplete 3, MX4, Yellow Tools all Mac Intel ready and they won't show up in my plugins list?
Please help... Thanks |
Hello,
I have just downloaded the 7.1.1. version and I can't install it on my dual core I-mac. When I try, the error message is (in french, because I am french, nobody's perfect): "Codec dépassé" wich may signify that the codec is not updated, but I'm not sure... Thank you in advance for your help ! |
I've installed this new version a couple of days ago, every worked fine, till today. I'm using an M-Audio Solo soundcard. I tried opening up a session from the studio (TDM) with a sample rate of 88.2 KHz. Right after this I couldn't hear any sound anymore, I opened up iTunes to listen to something, and I couldn't hear something either. So I closed pro tools, unplugged the soundcard, plugged it back in, restart the computer. Then I started up iTunes first, the sound was working again. I start up the same 88.2 session again, and the sound stops right away. I've never had this problem with 44.1 from the studio, but with 88.2 I have a problem, haven't used any other sample rates yet, but this looks like a bug to me, isn't it? Robin |
I just tried using the fasttrack pro soundcard for it (uses an other driver) and with this one it works so I think it's a bug in the driver, at least that is what it looks like to me. Robin |
Pro Tools LE 7.1.1 for Intel-based Macs | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 126 | 10-18-2006 06:27 AM |
Pro Tools LE 7.1.1cs2 for Intel-based Macs | alx002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-11-2006 02:42 PM |
Pro Tools LE 7.1.3 for Intel Based Macs ???? | bortraws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-30-2006 01:28 AM |
PLugins and Intel-based Macs | JaeM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-20-2006 03:47 AM |
Pro Tools LE & M-Powered 7.1.1 for Intel Macs | Avid | General | 0 | 05-30-2006 09:08 PM |
