Hey guys, I just bought a used 003 rack, and I don't have any manuals, but just a quick question:
When I turn it on, without anything else plugged in, it takes about 5 seconds, it clicks about 4 times and the lights flash in weird ways. Is this a normal power up procedure? I came from the MBox 2 so my only question is just that... |
![]() Quote:
When it's finished you should see a small yellow light about the middle of the unit that is labeled HOST (your 1394 connectivity). Also the red MUTE button will be lit. If you use any sort of a midi controller with it (plugged into the back of the 003), I found that I need to hit a key on the controller right after turning on the 003.. or sometimes it doesn't know the controller is there and you have to exit PT and start again to get it to work. You will really enjoy the 003. (although updating the firmware can be a bit of a bugger sometimes) Peace!
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
![]() Quote:
I have to go download the manuals, I'm curious about how much power it will draw if I leave it on all the time... |
One more thing: It's asking me if I want to update the firmware from 7.4 to 8.00 etc.....
SHOULD I? What is the most stable firmware version?.... I'm scared to trust Digi on this... PS: I'm updating right now, with the 003 plugged through an external firewire drive.... PPS: OK it's been updating for 20 minutes now... :/ |
Let it run...worth the wait.....and if your running 8 it's required....
Mac 8 core 2.8GHZ 4GB RAM, 4TB Disk, OS X 10.6.2 HD1 core card, 192 i/o, behringer ADA 8000 mic pre, symetrix sx202 mic pre, Behringer studio monitors, tascam cd-a500, SM58, Blue Baby Bottle,Samson co2, M-audio Keystation pro, |
Cool :) working now. seems good. Now I have to use it for a couple months, and I'll post back on the difference of stability of the audio engine, when compared to a USB bus powered Mbox 2...
you will like the 003 rack. Be sure to update Pro Tools to 8.0.1
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
![]() Quote:
My 003 Rack Normally makes the ticking sound then power up. However, For about a week now ....everytime I push the power button, it ticks once and does not come on. I have to keep switching between the on and off position before it eventually stays on. What do you think is causing this? |
![]() Quote:
The 002's had an issue with their power supply, but I've not heard much of anything bad about the 003 at all. DTS may chime in here. If it were me, I would look at repairing it.. depending on the cost, maybe investigate the Black Lion Mod for it.. (some folks like em, some don't). It may end up being something as simple as a power switch or it could be a processing board.. Honestly, Good luck with that one..
Digi 002 rack power supply | tromnek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-30-2012 03:06 AM |
Correct Order to Power Up & Power Down Digi 002 Rack? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-12-2008 06:57 AM |
Configure Digi 003 Rack to Output "normal" Audiodata?? | reiterw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-09-2007 03:15 AM |
digi 003 rack won't power | ssack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-02-2007 01:56 AM |
Power consumption of Digi 002 rack? | rsgilbert3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-22-2006 01:19 PM |
