Digi 002 Rack need help - digital output to CD recorder
I am running Pro Tools 7.4. on a Digi 002 rack
Trying to record to a Fostex CR500 CD Master recorder via digital output from Pro Tools. The configuration I am using is as follows: SPDIF digital out via the RCA jack using a 3m SPDIF cable. SPDIF cable into a HOSA CDL-313 Coaxial(RCA) to AES/EBU converter. AES/EBU XLR style cable from the CDL-313 to a Fostex CR500 CD Master recorder (AES digital in) No return loop is connected. Settings on the CR500 are correctly set up for digital input. I set the output of the desired track in Pro Tools to S/PDIF 7-8. When I attempt to record, the Fostex CR500 acts as though it is recording, but there is no audio present when completed. I have tried inserting a master fader, but to no avail. I'm really struggling with this, I would really appreciate any assistance. |
Re: Digi 002 Rack need help - digital output to CD recorder
Your spdif output needs to be set to spdif and NOT adat.
Are your sessions 44.1khz/16 bit? I'm guessing the Marantz doesn't have any kind of on-board converter. BTW, you should ALWAYS have a master fader in there anyway, not just as a last resort..... |
Forgive the ignorance, but where to I set the output to SPDIF instead of ADAT?
OK, so I configured the optical port for SPDIF (there is no option for the RCA port) which deactivated outputs 11-16 in the I/O screen. Moved the SPDIF output to channels 9-10 in the I/O screen, which are still active. Still no audio from the digi rack to the CD recorder. Any suggestions? Anyone?
Again, when you first created your session, is it 44.1khz/16 bit?
Hold the phone.....your master fader output should be set to the Master 1/2-spdif option. Try that.
But you STILL need to be 44.1khz/16 bit. |
Digi 003 Rack ADAT Output To ZED-R16???? | Project3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 17 | 02-17-2010 11:55 PM |
Left output of Digi 002 rack quieter than right. | Illl0lll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 12-27-2009 03:58 PM |
Digi 003 Rack not available as sound output option? | DSwartz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-13-2008 10:58 AM |
Analog Recorder Connections>Digi 002 Rack | Randirainbow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-17-2005 06:29 PM |
Digidesign 002 Rack VS Roland X6/Digital recorder | DavidLV | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-01-2004 02:45 AM |
