Old 03-02-2021, 03:45 AM
flautista's Avatar
flautista flautista is offline
Default Can’t connect Mbox 3 Pro High Sierra
I can’t Connect my mbox3 pro
to my MacBook Pro 2012 High Sierra
I tríed the last three drivers
10.3.6
10.3.5
10.3.2 doesn’t works any
The MacBook reboot again and again
When unplug the mbox I open the the mbox interface app
Show the versión driver but not the number of the
Firmware
On windows is working
Any help thanks
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 03-03-2021, 09:00 AM
lancemcv lancemcv is offline
Default Re: Can’t connect Mbox 3 Pro High Sierra
It’s your lucky day... maybe. I had the same problem and found this post and it also worked for me.
I had the same problem but have finally found the solution after a lot of head scratching. Hopefully you did the same thing as me anyway and this fixes it for you.
I remembered when I installed the driver a pop up came up and in my haste to get things working (ironically) I didn't read it and clicked OK (In blue making you think you should press it) and carried on the installation. Anyway, that pop up was the critical part, you need to click to allow extensions by "Avid Technology Inc".
No matter how many times I uninstalled and reinstalled the Mbox Pro 1.3.5 driver I couldn't get the pop up to display and I couldn't see a way to manually add the extension exception.
This is how I fixed it.
1. Uninstall 1.3.5 driver
2. Install the incorrect Mbox (Not Pro) driver 1.2.13 but this time clicking 'Open Security Preferences' and adding the exception for extensions by "Avid Technology Inc".
3. Unistall 1.2.13
4. Install 1.3.5 driver again
The Mbox Pro now works!
I hope this helps.
Pro Tools Ultimate 2021
opencore 0.6.9
Mac OS Big Sur 11.2.3
Mac Pro 2009 upgraded to 5,1 12 core 3.33ghz
GPU RX5700XT, Samsung SM951 M.2 PCIe SSD (AHCI model) pcie boot drive, Sonnet usb 3.1 card
Midas M32r console. iPad Pro with Avid Control
Old 03-03-2021, 09:38 AM
flautista's Avatar
Thanks so much
I’ll try and tell you later
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 03-04-2021, 05:58 PM
flautista's Avatar
3. Unistall 1.2.13
I hope this helps.
Not working
Doesn’t show Avid Tecnologies óption en Security
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Mbox Pro 3 not recognized on High Sierra javisrodriguez FireWire & USB Audio Interfaces (Mac) 0 03-02-2020 09:48 AM
MBox pro Driver problems with High sierra 10.13.6 BORIS C FireWire & USB Audio Interfaces (Mac) 7 02-16-2019 04:10 AM
Mbox 3 and Mac OS High Sierra compatibility MarcelMendesFilho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2017 03:29 AM
Does Mbox work well with High Sierra? aonis FireWire & USB Audio Interfaces (Mac) 5 10-21-2017 07:26 PM
Mbox 3 with High Sierra francois FireWire & USB Audio Interfaces (Mac) 2 10-11-2017 04:55 PM
