Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-08-2009, 03:20 AM
shiama shiama is offline
Default Fw Ext Drive damaged
Both my ext Fw hard disks connected to my M-audio 410 are damaged and are not mounting anymore. Is it possible that the M-audio 410 is the cause of this? At the begining I was thinking it was an issue related to my laptop but
the mac specialists said my laptop is ok.
Is anyone else experimenting a similar issue ?
I m now trying to recover all data on my ext drive but before connecting my
FW 410 to a new drive I wonna be sure this is not the cause of the damage..
thanx
shiama
Old 10-08-2009, 06:57 AM
sunburst79 sunburst79 is offline
Default Re: Fw Ext Drive damaged
thanx
shiama
At least in LE land Digi recommends connecting the drives and the interface like this. Computer>HDD> Interface -This way if the interface is accidentally powered off it wont corrupt the data on the HDD. Not sure that M-Audio recommends the same connection scheme but the information is offered as it sounds like the most likely culprit of data corruption in your case.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 10-09-2009, 05:22 AM
actually M-audio suggest Computer\interface\Ext Drive.
This was the sequence I v been using mostly...some time I was also using the other way around as you suggest...lately only the second solution was working...at the end both ext HD were damaged....I do not know if the cause was the M-audio interface ...any known issue related to this?
On the M-audio forum no one is answering..hope to have more luck here..
thanx
Shiama
Old 10-09-2009, 10:55 PM
mingustoo mingustoo is offline
run disk repair under disk utilities and also dis warrior if you have it. If you dont have it...get it. And always eject/unmount disks before shutting them off. Remember it is also most likely the enclosure that is damaged if there is actual mechanical damage. I find the enclosures last about one year in (sh)city air.
Old 10-10-2009, 12:35 AM
I v tried disk repair and all that Digi suggestion but nothing worked out.
Now my ext drive is in the hand of a data recovery expert in Bangalore.
They ll open it and try with a different enclosure...
The M-Audio expert said it could be caused by hot plug in the M-audio interface. New Mac even wen shut down send power to the firewire port and this could be the cause . According to him this is becoming a hot issue
This is the link to the same topic in the M-audio forum
http://forums.m-audio.com/showthread.php?t=12827
Old 10-10-2009, 01:16 AM
could you plz send the link to that digi suggestion?
Can't find it but I would be interested in finding out what is actually the best
way to chain Interface\ext HD\ Laptop
Old 10-12-2009, 09:39 AM
moskasound moskasound is offline
I recently had a similar problem with my two LaCie Quadra drives. Both went down at the same time. Replacing the power supplies got them up and running...no problems since.
Old 10-12-2009, 11:50 PM
Hi, you mean it was a failure of the lacie power supply ?
I was also using two Lacie Hard drive but one of them hasn't a power suply cauz is powered directly from the lapt top FW port.
Old 10-13-2009, 01:29 PM
mgarza mgarza is offline
This is my setup
Ext.D ---fw--- Audio Interface ---fw--- Computer
Lacie Little Big (320)
M-Audio Profire 610
Macbook OS 10.5.5
I've been using this setup for about a month working on projects 3 or 4 times per week... I haven't had this problem...yet...
where there any sings of ext.d malfunctioning before?..."if you keep doing that, I'm gonna stop working" kinda thing
Old 10-13-2009, 02:16 PM
It should be in your manual.........
Scott
Core 2 Specs Page
Pro tools SE 8.0.3 damaged CD djbigbiz Pro Tools SE and Essential (Win) 8 01-04-2013 09:25 AM
Damaged M-Powered 8 DVD Moobs Pro Tools M-Powered (Mac) 12 04-29-2012 09:03 PM
PT Install DVD Damaged ? markus44uk Pro Tools TDM Systems (Win) 6 03-12-2009 04:26 PM
Damaged PCI Cards Plastik909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-06-2003 12:45 AM
SPDIF I/O damaged ??!! ongaku 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-22-2001 08:07 AM
