Bass Guitar
I have been working on numerous songs and am trying to get the bass parts recorded now. I have been going directly into the 002 rack and it hasn't been sounding all that great. I've tried EQ, slight overdrive, and comressing, but I still cannot get the sound I am looking for (which is thrash/black metal)
I am a guitarist/producer. I can transition to bass pretty well, so I know its not a technique issue. With using what I have, I am not getting the bass to sound right. I don't have a bass amp, so Direct In is the only way to go. With using only what I have (bass, EQ and compression plug ins and 002 Rack) does anyone have any suggestions? Thanks
PTLE 7 Digi002R, Intel P4 HT 3.0GHZ w/ 865 Chipset, 2GB (4x512)RAM PC3200, WinXP Home SP2, 160GB 7,200rpm, 74GB 10,000rpm |
Re: Bass Guitar
Maybe try demoing some plug-ins like IK Multimedia AMPEG SVX and or try using a guitar plug-in like Eleven (never tried on Bass specifically but amazing on guitar for adding life to a lifeless instrument!) or even Metal Amp Room by Softube for a dirty growling bass or distorted bass sounds.
I'd try them in that order too. It's all personal preference so just gotta try em out and see. I believe those are all fully functional plug-ins as demos too. Report back and let us know how it goes~!
Re: Bass Guitar
I believe Izotope's Trash lite comes with the Ignition pack!
Try this one. Another suggestion is Amplitube or Ampeg Uno. Hope that helps!
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Re: Bass Guitar
I usually split my signal path and use amp sims on both. For example I'll record the bass direct and put the output of that track to two aux's. On each of those I'll have a amp sim, one clean, one distorted. I then mix those to my final bass tone. Usually I'm using my SWR head as a pre-amp recording direct, then on one aux I have Amplitube just using the bass speaker emulation (my clean channel), on the other aux I use AmplitubeLE for the distortion channel (I found I like the LE version best for bass distortion even if it won't reset the saved settings properly!).
Re: Bass Guitar
Amplitube works for me.
I also had a similar problem with a band - where it ended up being the guy's bass itself (even though it was a Fender Jazz). When I recorded it direct, it sounded like crap. I had a newer bass (schecter) with active electronics - that has a great sound when recorded direct. |
Re: Bass Guitar
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Bass Guitar
How about a really cheap little tube pre-amp? Spend maybe $100 or so. It's hard because DI bass really will always sound like cardboard and crap compared to a decent mic pre. By that I mean I record without an amp alot, but I run it through my Avalon 737sp or sometimes I use my Focusrite ISA where I can change impedance. The thing is that no matter how many plug in's you use, if your source signal isn't good the output won't ever sound tasty.
If you really need some love, why not rent a piece of gear or buy one from Sweetwater on a credit card and return it... girls do this at prom all the time with dresses. I mean, especially if you are trying to get a serious product pull out all the stops. D |
Re: Bass Guitar
The IK SVX is a good suggestion...
so is the idea of a direct box instead of plugging straight into the 002 I might recommend the Tech 21 Sans Amp Bass Driver DI or RBI. You can use it either as JUST a better DI than the 002 input, OR you can do some tone and distortion shaping in the Sans Amp and might find you don't need the SVX. also, do you have a GOOD bass guitar? lastly, forgive me but I've found over many years that it's the RARE guitarist who actually CAN play bass guitar to sound right (even though they all think they can!) Don't take it for granted.
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
Re: Bass Guitar
Thanks for the suggestions. I will look into a decent pre and go from there.
Re: Bass Guitar
Just to clarify, I don't think anyone said a PRE.
just a DI. you'd still be using the mic pre in the 002 (via its XLR input) after the external DI
Make a guitar sound like a bass guitar | carterisgod41 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-17-2011 01:36 PM |
Bass Guitar | xsane | General Discussion | 1 | 12-25-2004 11:55 PM |
Guitar/Bass Set-Up - necessary??? | eldangeroso | General Discussion | 17 | 06-11-2004 09:49 AM |
Real bass guitar...Midi bass guitar... what to you put on em to make em sound great ? | Jorge442 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 09-05-2002 11:41 AM |
How to set up your own guitar or bass... | Roy Howell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-26-2002 09:18 AM |
