Disk Allocation Question
Hey Folks:
A session I am working on came in as a Logic session. I imported the regions (From the client CD) into my firewire drive (Archive drive), created a new folder called "Song Name PT" to indicate it being a Pro Tools session. Okay, The person who did the session in Logic didn't name any of their files so I had to sort through 300+ regions to find Drums, Piano etc. I was able to recreate the session in PT. I moved the session over to my "Work Drives" from my Firewire drive (Getting ready to mix). This is my dilemma, the session's disk allocation is showing the Archive drive (Firewire) and the session is clicking and popping like crazy. Now, I know there is a limit on the amount of tracks that a firewire drive can play. However, the session I recreated is now on my work drives (ATA and SCSI). Why doesn't the disk allocation show where the regions currently are. I've even deleted all regions imported from the FW drive and it still shows in the allocation. What the H*&L is going on? Warren www.brownstonerecordingstudio.com |
Re: Disk Allocation Question
So change the allocation. Go to the Setup>Disk Allocation and change all the tracks to your SCSI drives.
Then close the session and delete all your fade folders on the FW drives. Then reopen the session and recreate all the fades on your newly allocated drives. As long as you don't excede the track count you should be okay. Note: You can't mix SCSI and FW in a session. I guess playing audio off SCSI and going to fade files on your FW drive won't help. and Remeber that Disk Allocation only governs where new audio is recorded, not where existing audio plays back from. |
Disk Allocation Question | Torchlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-14-2007 07:25 AM |
Disk Allocation question | lordofgain | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-19-2004 08:36 PM |
Disk Allocation question | Ted Blaisdell | Pro Tools TDM Systems (Mac) | 1 | 04-08-2004 07:28 AM |
disk allocation question | Viktor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-20-2003 03:03 AM |
PT6 disk allocation question | protooleriate | Pro Tools TDM Systems (Mac) | 0 | 03-01-2003 02:59 AM |
