Old 10-12-2013, 08:08 PM
juicytunes juicytunes is offline
Default can't record
Hi guys,
I'm not able to record. Says I can't save session.
Check disk allocation and if read only disk, or some such message.
My drive is set to record, and the allocation is to the drive
I get error (-50).
also having trouble ejecting my drive - "the disk -- wasn't ejected because one or more programs may be using it". This is after I've quit pro tools.
Anyone know what's happening here?
I tried trashing preferences.
Running pt 10 on an imac.
S
Old 10-13-2013, 01:44 AM
Phil Ogden Phil Ogden is offline
Default Re: can't record
Does the HD have read & write priviledge at OS level? check using Apple I.
Old 10-13-2013, 05:08 AM
Originally Posted by juicytunes View Post
Hi guys,
I get error (-50).
S
A few more details on your computer setup would be helpful - just saying PT10 on an iMac isn't enough. Are you trying to record to the system drive? Not recommended. -50 message could be a precursor to a drive going bad - happened to me.
Why are you trying to eject the disk?
Old 10-13-2013, 08:21 AM
I'm recording to the external drive ( G -drive ).
I tried to eject the disk so I could restart. I have drive > mbox pro 3rd gen >
computer. I"m supposed to start things in order, so if I restart, I turn on drive, mbox, computer.
Thanks.
Old 10-13-2013, 09:14 AM
Thanks.
You don't need to eject a drive to restart or shut down a computer. Just shut down like normal and then shut power to the drive and the interface. What is a G-Drive? Specifics please and how it's connected to your iMac. If it's a green drive that's a no-no.
And again - we need more info on your computer setup like what's in the iMac, memory, OSX version, PT version (not just that it's PT 10).
Old 10-13-2013, 11:13 AM
Hey Phil - yes I do have read and write permissions.
Musicman -
thanks - Is there a difference between ejecting, and just shutting down and turning off? I thought either was ok.
G drive. No, it's not a green drive. http://www.g-technology.com/products/g-drive.
connection is drive>mbox pro 3rd gen>computer
It's imac 10.6.8 w 8gb memory and pro tools 10.01
I hadn't had any issues. That's what's bizarre. Just happened yesterday, after being fine for, I don't know 2 yrs??
Today, I started up, it took forever ( few minutes ) for the drive to show up on my desktop, and then everything was fine. All working. Strange.
Old 10-13-2013, 02:57 PM
Musicman -
There's no difference but why go through an extra step when shutting down? Just shut the computer down with the drive still mounted and powered and then shut the drive and any peripherals down after the computer is done shutting down.
You're only on 10.01? That's an old version, latest is 10.3.7. Check disk allocation in PT and make sure the drive is okay to write to (this is separate from read/write in OSX).
Old 10-13-2013, 03:03 PM
Yes, as stated in original post, I checked disk allocation, and drive is set to record.
seems bizarre, but seems to be fine right now.
Old 10-13-2013, 03:18 PM
Glenjb Glenjb is offline
How old is the g drive? Could be giving u signs that it's about to go. I would back it up if you don't already!
Old 10-13-2013, 03:34 PM
Thanks Glen. I think it's about 2 years old. Doesn't seem that old??
Musicman. I guess at one point I thought it may be preferable to eject the drive, but I guess that's not the case. The other reason I eject though, is sometimes, I'm done using pro tools, and just want to surf the net, and figure I shouldn't just leave the external drive running all day. Does this make sense, or it's a bad idea?
Session must be on an audio record volume if permmited set the volumes to R record lionandthemouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-11-2013 01:48 PM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
MIDI record enabled and found but wont record BCRich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-23-2010 12:51 PM
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts The Muphin Man Pro Tools SE and Essential (Win) 8 09-10-2010 07:03 PM
Crackling in record mode (even when not actually recording), cannot record > 10 secs chandra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-16-2010 09:08 PM
