Grabber tool wont respond on Slip Mode
The grabber tool or the trim tool won't work on Slip mode just on Grid mode, does anyone have an idea what could it be? I am running a 7.3.1. cs6 Version Thanks! |
Re: Grabber tool wont respond on Slip Mode
Maybe I didn't explain myself right.
Two days ago it was working fine, yesterday the grabber tool and the trim tool failed to respond to my mouse. I can make it work using the f6 & f8 keys, but not with my mouse alone the odd thing is that grabber and trimmer respond to my mouse just on grid mode... is there a way i deactivated on slip mode? Many thnaks in advance. Efren. |
Not totally sure I'm following you, but it kinda sounds like you're used to the Smart Tool feature being on (press any two of F6-87 together). Or do you mean that when you click the tool icons with the mouse, it doesn't change the tool? Exactly how do the tools fail to respond? Does the cursor not change to the right tool shape, or does the tool not cause the audio to move, or...?
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Hey David,
This is the situation: When working on Slip mode, I click on any of the tools icons and it does changes the tool to the one I am going to work with (If I click on the Grabber the cursor changes to the hand, if I click on the Trimmer changes to "[" or "]" depends of the position of the cursor over the region) until here everything seems to be normal. The problem is (Let's say I have already selected the Grabber tool) I select the region with the hand (one click over the region and it selects it by changing the color) then I press click again and hold to move it and It won't move! same with the Trimmer it just won't trim (The track is on waveform view). This happens only on Slip mode , neither the smart tool or the "individual' tools respond. I really don't don't if I accidentally clicked a combination of keys disabling something or this is a nasty bug... I am working on a Factory 003 running PT 7.3.1. cs6. Thanks for following this up! Efrén. |
Hi again,
I was able to make it work. I just went to my back up session files and found one that it was working. I also checked other sessions I have and all seems to be working OK. I wonder if it was a corrupted .ptf file... I would like to know how a session can get corrupted? I don't use the computer for internet, I don't use USB memory drives. I am pretty sure my computer is 100% safe of viruses, this was a malfunction within PRO TOOLS, no doubt. Is there anyone from Tech Support willing to answer this? Thanks. |
Possibly you wern't in wav edit mode, you can not edit if you are in mute, volume, etc... |
I was on waveform view. That was the first thing I checked. I was working with 8 tracks all of them on wav edit mode.
Yeah, it might have been a corrupt session file. It's possible for any file on any computer to get corrupted at any time. It's rare, but it does happen from time to time, and the more a file gets used, the more likely it is to happen to it. It can be caused by a tiny bad spot on the disc, a temporary instability of the system, a poor connection somewhere, a bug in the OS, a bug in the program, and probably any of a number of other things. To paraphrase Murphy, if something can go wrong, it probably will sooner or later.
It will probably never happen to you again, but if it does, we'll have to take a close look at your system specs and do some detailed troubleshooting.
Is is possible to change the shortcuts for the Pencil Tool, Grabber Tool, ETC? | jgagne1 | macOS | 2 | 09-24-2013 07:46 AM |
Get Grabber tool (Object) as part of smart tool? | buckaroo | Pro Tools TDM Systems (Mac) | 8 | 07-13-2010 04:21 AM |
Grid mode, shuffle mode, spot mode and slip mode. | RogTaylor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2010 10:30 AM |
Problems with Grabber Tool & Trim Tool | S133 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-05-2008 10:19 PM |
smart tool gets stuck in grabber mode | jimlongo | Pro Tools TDM Systems (Mac) | 0 | 06-08-2006 07:01 PM |
