AVID ASIO control panel don't change ASIO buffer size
we upgrade to a AVID HD NATIVE system (Win 8.1 x64). In PT 10/11 everything works as expected. But, we are also running different DAWs like Presonus Studio One 2 an so on. Therefore we need the AVID ASIO drive to run as expected. We can bring up the AVID ASIO control panel from inside a 3rd party application but we can't change the buffer size to any different than 1024. Is this a known issue? I couldn't find anything about this around here and google. I tried to deinstall the driver (AVID HD driver 11.3) and reinstall it with out any succsess. To clear this out, i can use the dropdown menu to select something down to 64, but after i hit "okay", it won't change to anything and will stay at 1024! System is Win 8.1 x64 PT11 HD (including the AVID HD driver 11.3). I/O is a HD I/O (analog) and a blue 192 I/O. If someone has an idear what to do, please give us some help with this. |
Re: AVID ASIO control panel don't change ASIO buffer size
can someone plz take a look into this? Still can't change the buffer size for ASIO in 3rd application... |
You have to run the other applications as an administrator. This will allow them to have full control over the HD Native asio drivers. Without this option, you can't change buffers or sample rate.
Martin Trum |
I have got the same problem, cant change the sample rate (it is fixed to 44.1) when I use asio4all. Please could you explain what to do as an administrator?
Thanks a lot |
With Windows you also need to make sure that the interface you're using for Pro Tools is NOT the default interface for Windows sounds/audio. Use your onboard sound card for other audio and your PT interface ONLY for PT.
Cheers,
My 003 Rack doesn't have any problems being used for both (though, obviously, not both at the same time...I don't think...but I haven't tried it.) Of course, what The Weed outlined is a very useful step when troubleshooting...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Hi Bill,
Couldn't do it with PT 11 and my 002 Rack (I know not supported, but that just means not tested, the 002 Rack works fine otherwise). I had to re-enable my onboard sound card in BIOS and make it the default for Windows audio. I found the tip on the forum, so it's well documented by users. Cheers,
actually i think AVID should write that in BIG LETTERS in there manuals... well, what ever - thanks a lot for your help there! |
2. hit the compatibility tab 3. click the check box: "run as administrator" 4. click apply 5. start protools 6. chance your settings - and cross fingers it works ;-) all the best |
ASIO Device Properties Have Changed by Control Panel Error | dougdude9 | Pro Tools 11 | 11 | 01-12-2015 12:34 AM |
Potential solution for ASIO Audio Control panel issues of Firewire | Joe.LoDuca | FireWire & USB Audio Interfaces (Win) | 18 | 12-20-2014 06:06 AM |
Error: ASIO device properties changed in control panel | Joe.LoDuca | Windows | 15 | 12-02-2014 08:31 AM |
Need Help - PT 10.3.2 ASIO Buffer Size | edwar64896 | Windows | 3 | 02-28-2013 04:31 AM |
ASIO, AM3 - Lowest Buffer Size? | Rock_Artist | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-22-2002 04:38 AM |
