Structure Full showing as Structure le
Recently got the PTIEP, and upgraded to Structure. Some of my projects are showing “le” in the insert browser, even though it calls up the full version. Already checked my library/application support………, and the only structure plug in the ‘Digi plugins’ folder is the full version. Don’t know why, and it really does not hinder my job, just want to prevent any future problems. Seems strange that the ‘le’ is still visible although it is not present .
Any solutions?
Music is the Message |
Re: Structure Full showing as Structure le
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
It happened to me and I solve it uninstalling and stalling PT back again.
I know ,it's a pain. |
I cleared the prefs and deleted the database with the Tech Utility. That correctly changed the Structure LE name in the insert plugin list to Structure. I had LE installed before installing PTIEP.
Hope that'll fix it for you.
Bortraws |
Hey!!! Thanks for the replies. I will try the easy ones first, then if no results, the re-install. It’s not a big a pain as dl’ing the expansion packs….. Thought I’d never get finished. Or try installing the East-West Composer complete bundle when you’re pressed for time
Once again… Big Thanks!!!!
But, still confused as to why it doesn’t automatically convert the old projects to Structure full. Used to wonder the same about Eq/Dyn2 to Eq/Dyn3. If you didn’t have a preset, you would get a default setting. At least Structure retains is patch.
I was just guessing that since the original patch was saved as a Structure LE file it would load as one and then would convert to Structure upon closing the session. Good to know. EQ2 and EQ3 are completely different plugs.
Anyone know where the Tech Utility lives in the new Avid.com site? I'm having some difficulty locating it, and I have the same issue with Structure LE showing up where Structure Full should be.
Thanks in advance! NL |
http://www3.digidesign.com/index.cfm...4&itemid=25974 Top of this page Legacy Digidesign Support Section
Structure LE and Structure Full Question | philip888 | Virtual Instruments | 6 | 09-28-2011 11:33 AM |
Structure Showing up as Structure Free? | Roper Band | Virtual Instruments | 4 | 06-02-2010 02:43 PM |
Structure Full vs LE Content | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-02-2010 03:33 PM |
Structure LE WITH Full Structure ? | jlvalero | Virtual Instruments | 2 | 10-16-2009 01:37 PM |
can't open Structure LE in Structure Full version | walter rohrbach | Virtual Instruments | 7 | 08-10-2009 03:02 PM |
