EQ question
I am done recording and have come to the mixing stage once again. I have a greater understanding of EQ theory than I had before, and I am getting a much better balanced mix overall... My one problem is clarity. See I cant figure out if it is the monitors or the room, but it sounds clear in the room, and muffled in a car, or home stereo. So I tried bringing in a refference CD, and then compared... I started to try to EQ the mix (while mastering) and comparing to a paz analyzer. I cant quite catch a good frequency for clarity/crispness without it sounding to harsh and thinning out the mix. Is there anyone who has a similar problem or solution? The mixes are not muddy. Am I aiming for my mixes to just sound clear and even, and gain the clarity and crispness at mastering, or is this something that I should be worried more about when I am mixing. Once again it sounds very good through the monitors, but so far away when it is in a car or on a home stereo. help! |
Re: EQ question
I'm not an expert, but I think you should finish mixing, THEN go about trying to master it. As I've been learning, I've been keeping EQ III on my guitar tracks (and other tracks) right in the mix, then when I come up to needing the Master Fader, I add another EQ III onto the inserts on that and tweak everything for a final time right there. Again since I'm not a pro, I'm not sure what others would say about this, but personally in my testings I've found it seems to liven up everything just a bit more! And of course, you then use compression and all those other plugins on the Master that you'd normally use... but since we're talking EQ's, I'll leave that for others to tell you.
As for the comparing to another CD, that's definitely a good idea. You know what else works, IMO? A few things, try listening through headphones. In the mixing process, I wouldn't worry if they're studio headphones or discman headphones, as long as you're used to how they sound with regular CDs. Once you feel you've mixed the crap out of something, mastered the hell out of it, then grab a CD-RW (RW, not a normal CD-R) and burn the song onto that (Not recommended for long-term audio care...). This way, without wasting a CD-R, you can take the CD-RW to your car, play the song and listen to it, do any comparisons there, then go back into the studio and tweak the song in different ways. And because you used a CD-RW, you can keep using the same disc over and over again to compare future mixes. The reason not to use CD-RW for long term is because the files kind of fade off the disc, sometimes completely losing the song(s). But the song(s) should last long enough to compare (I'd say you'd have at LEAST a month of safety).
Kryst |
Re: EQ question
It's not how much you eq your material. It's how well you can trust your equipment. If your mixes sound good where you mix it, then your only problem is getting it sound as good elsewhere, so forget tweaking the eq if you're satisfied with what you hear from your monitors.
Re: EQ question
Where exactly do the converters affect the mix?
Re: EQ question
While I agree that converters will affect the final, I think you need to back up and consider some much more basic things before you worry about that. First, monitors. Crappy speakers make for crappy sound. While some engineers that are highly experienced, can "learn" crappy speakers and create a good mix anyway(damn those NS=10's), a lot of us need to have accurate speakers. Second, room treatment. A set of great speakers in a bad room will still sound inaccurate. In either case, inaccurate monitoring will result in mixes that do not transfer to other systems well. For instance, if your speakers are weak in the low end(or your room has low end troubles like 80% of home studios) you might be adding EQ trying to make the bass sound good. Now when you play that on another system that has good bass responce, your mix sounds bass-heavy. Maybe your tweeters are a little too hot so you EQ the top end to sound smoother. Now on another system, your mix sounds dull. Starting to see the pattern? I highly recommend that important mixes go for mastering by a pro(or at least by a fresh set of ears, listening to good monitors). Mastering is part art and part science and although I have done several projects(due to budgets) I still prefer to farm it out. I certainly applaud you trying as its the only way to learn. You made a good call by using the PAZ analyzer but you could also try importing a wave from a commercial CD and see what that analyzer looks like with a recording you like. Just don't expect awesome results until you have invested a ton of time. My 2 cents-great converters will put that last polish on a project that is near-perfect.
Re: EQ question
Once you get good converters (assuming you already have good monitor speakers), your mixing decisions will make your mix translate better between different systems.
Re: EQ question
(The same thing with recording chain: the earlier parts of the chain are always the more important ones. You cannot get a crappy song shine no matter how good-sounding mic you use. Or you cannot get a good bass sound if you're recording a crappy bassist. You get the idea.) Quote:
Re: EQ question
Better converters and better speakers may (and usually do) help, but more importantly (and cheaper), learn what you have. Listen to your mix and try to figure out where and how it sounds different. For instance, if you notice your mix is really distorted on tiny speakers and seems "stuffy" maybe you have too much low end. One trick to getting "more" low end is to cut low end and turn up volume. For instance, use a high pass filter at 30 hz or so to cut out rumble, then turn up the fader. Dave Pensado said in an interview regarding eq on bass- turn up the fader then get rid of what you don't want on there with eq rather than just turning up the bass knob, and it does make sense. Anyway, just listen to your mix and pay attention to the things you hear and you start to learn how to make things translate. As you get better and situation allows, get better tools, but remember, better tools only make things easier, you still can do the best with what you already have. Hope that helped.
Re: EQ question
I have spent 5.000 on my mix environments in the past, demoed speakers I cant even pronounce, all kinds of crap. Although all of these people are right, my breakthrough, after falling short on several mixes, was to relax. Thats right, take a few days and relax in front of your speakers, don't mix anything and listen for as long as you can stand. As a freelance Engineer, I can count on nothing other than my reference CD's and I always spend at least an hour and a half just listening to a room on my first day. This is free and will most likely produce the best results for your growth and the quality of your mixes.
By the way, with PT LE you should stray away from putting things on your master buss. -s |
Re: EQ question
If I may ad my two cents. Reading the previous posts I would say everything stated is correct. There are so many issues that effect the mixing pocess and a few were mentioned in these posts. You should learn to mix on the equipment you have. I have Alesis Monitor ones and yes I would love a new pair of monitors but I can create great mixes from them because I know what to listen for. What I would do is do a mix of your song and burn that mix and a professionally mixed song thats close to the instruments used in yours and compare the to. Are vocals clear,guitars blended, kick punchty...etc. Your best equipment is your ears. Again, better converters,monitors,etc will make a mix Definetly sound better but I think to you need to learn how to balance and blend everything with what you have. You'll sound that much better when better equipment is more relevent. Sorry, better equipment is always more relevent. I hope you get what I mean.
iMac 27" 3.4 GHz Intel Core i7 Pro Tools 10.3.10, Digi 002, Octopre w/Adat light pipe, Glyph GT052 |
fruity loops in pro tools question...not regular rewire question | nutrinoland | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-23-2010 12:39 PM |
quick question - Mbox Mini question - i forget | JRup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2009 02:55 PM |
Another optical expansion question question for boffins | Che_Guitarra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2008 11:21 PM |
General Venue Automation Question - (Maybe dumb question) | TwoPort | VENUE Live Sound Systems | 5 | 12-21-2007 02:41 PM |
Chipset Question/Hard Drive Question | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-26-2006 08:15 AM |
