Volume question using instrument track
I am trying to use an Alesis keyboard into PTLE7 and I am going out of the keyboard into the 1/4 inputs on 2 and 3 in the PT hardware.
I am not able to get any volume save barely a sound and I have the gain turned up and the slider turned up on the software and am not getting anything. Any suggestions before I resort to the manual |
Re: Volume question using instrument track
What hardware do you have?
You should use one of the built-in stereo pairs for the input, it'll be easier to monitor in PT that way (use inputs 1-2 or 3-4 etc. using 2-3 means you need 2 mono tracks or you have to change your I/O settings). You also want to use an Aux track for this, not an instrument track. Instrument tracks are for using Soft-synths and other internal sound modules (plug-in instruments). Reading the manual is always a good idea too, you would've found this info in the first couple of chapters. |
If you're using the 002, then don't forget to switch the inputs from mic to line via the grey buttons on the front.
002R PT7.3.1 MacBook Pro 2.33 OS 10.4.8 |
you still need to bus to an audio track to record the audio though
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
Right, I was kinda bypassing that part to try and make it simpler for him, but yes, you can actually do it with an Instrument track. I recommended the Aux track since it's the easiest way to test if the signal level is coming in right (bypassing any MIDI functions) and it doesn't require you to bus anything anywhere to hear your signal (which is also true of an Instrument track, but I've found from my beginner clients that Instrument tracks are very confusing for some reason - I think since you see MIDI but monitor Audio).
Instrument Track Region: Adjusting Volume? | johnbarnesiii | Pro Tools 10 | 1 | 06-21-2013 03:26 PM |
instrument track volume peaks when instrument volume knob is down | deadvisions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-12-2011 01:43 PM |
Can't Mute or Change Volume on Audio Track and Instrument track | FunkTools | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-10-2010 04:40 AM |
instrument track question | synchronic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-09-2009 03:11 PM |
Crash when adjusting Instrument track MIDI volume | Helge Krabye | Pro Tools TDM Systems (Mac) | 0 | 01-28-2006 02:33 PM |
