Hello Everybody....
i got a new pc is cpu: i5 750 mb: p55-gd65 ram:4g hard driver : 1T and 250G mbox2 i installed win7 32bit on "1t" , and xp 32bit on "250g" i installed pt8 under win7 first, it always stop at "dae is loading" when i try to run pt8, then i update to 8.0.1, it works ,but shows new error "check your clock source and sample rate" when i do every action of play ....... so i try installed pt8 under xp, the error becomes to "DAE -1115" i have no idea for those errors,hope someone can help me to solve .im going crazy.........thanks. |
![]() Quote:
To the OP, I agree with Benoni. You should start a total reformat. Leave one drive clear for your audio and partition as you like on the other.
Kryst |
![]() Quote:
I agree 100% about using the 1TB as the record-to drive. I also agree that we should have suggested the Sandra report. LOL Original poster, please Install and Run this for best results of help towards your problem
Kryst |
because the 1T be formated to a Dynamic disk by win7 Automatically that PT can't recording on it, but the 250G one is ok. so i installed xp and PT on that disk. but the problem still come out...so i guess it's the problem of usb??
i'll try upload SANDRA report later..thanks for your help` |
Hello Mokki!
The problems you are having seams similar to the ones I had recently. I managed to solve it though. You can read about it here: http://duc.digidesign.com/showthread...light=dae+1115
MOBO: ASUS P7P55D Deluxe | CPU: Intel Core i7 860 | RAM: Corsair Dominator DHX+ DDR3 1600 8GB | Video Card: NVIDIA GeForce 8600 GT | Windows XP Pro SP3 | Hard Drive: Western Digital 320GB x3 | Pro Tools LE 7.3.1 | Mbox 2 | Pro Tools M-Powered 7.3.1 | M-Audio Audiophile 24/96 | Apogee Mini Me | Apogee Mini DAC | Waves Gold Bundle |
![]() Quote:
i have been searched your post on google before,that's why i come here looking for help haha... but seems like it's a very big problem that not easy to solve...` |
Sandra report :
< Computer > Model: MICRO-STAR INTERNATIONAL CO.,LTD MS-7583 Workgroup: WORKGROUP Host Name: mokki-pc User: Mokki < Processor > Model: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Speed: 2.8GHz Cores per Processor: 4 Unit(s) Threads per Core: 1 Unit(s) Type: Quad-Core Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache: 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 4 threads sharing < Computer > Mainboard: MICRO-STAR INTERNATIONAL CO.,LTD P55-GD65 (MS- 7583) BIOS: American Megatrends Inc. V1.2 08/20/2009 Bus(es): ISA X-Bus PCI PCIe USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:No Total Memory: 3GB < Chipset > Model: MSI Clarksfield/Lynnfield DMI Front Side Bus Speed: 1x 134MHz (134MHz) < Memory Module(s) > Memory Module: G.Skill F3-10666CL9-2GBRL 2GB DIMM DDR3 PC3- 10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module: G.Skill F3-10666CL9-2GBRL 2GB DIMM DDR3 PC3- 10700U DDR3-1334 (9-9-9-25 4-34-10-5) < Video System > Video Adapter: NVIDIA GeForce GTX 260 (216 SP 1.3GHz, 896MB DDR3 2x1GHz, PCIe 2.00 x16) < Graphics Processor > Adapter: NVIDIA GeForce GTX 260 (216SP 1.4GHz, 895.7MB 2x1GHz) < Storage Devices > WDC WD1001FALS-00J7B1 (1TB, SA:932GB ST3250820AS (250GB, SATA150, 3:233GB (G:) (H:) BENQ DVD DC DW240S (SATA150:N/A (J:) < Logical Storage Devices > Hard Disk (G:): 122GB (NTFS) @ ST3250820AS (250GB, SATA150, 3.5", NCQ, 8MB Cache) Hard Disk (H:): 111GB (NTFS) @ ST3250820AS (250GB, SATA150, 3.5", NCQ, 8MB Cache) Optical Drive (J:): N/A @ BENQ DVD DC DW240S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Hard Disk (F:): 248GB (NTFS) Hard Disk (E:): 293GB (NTFS) Hard Disk (D:): 293GB (NTFS) Hard Disk (C:): 98GB (NTFS) System retention (I:): 100MB (NTFS) < Peripherals > LPC Hub Controller 1: MSI Ibex Peak LPC Interface Controller LPC Legacy Controller 1: T0 07-23h Audio Device: MSI Ibex Peak High Definition Audio Audio Codec: Realtek Semiconductor 0889h Serial Port(s): 1 Disk Controller: MSI Ibex Peak 4 port SATA IDE Controller Disk Controller: MSI Ibex Peak 2 port SATA IDE Controller Disk Controller: MSI JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1: MSI Ibex Peak USB2 Enhanced Host Controller USB Controller 2: MSI Ibex Peak USB2 Enhanced Host Controller FireWire/1394 Controller 1: MSI 3403h SMBus/i2c Controller 1: Intel 801xx/63xx SMBus < Network Services > Network Adapter: Realtek PCIe GBE Family Controller #2 - Packet Scheduler Miniport Network Adapter: Realtek PCIe GBE Family Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 2) Platform Compliance: x86 ---------------------------------------------------------------------- Is there any problem making DAE 1115 ?? ![]() Please help Thanks!! |
problem update,
sometimes i got DAE -1115 error and sometimes i can get in Protools, but the sound with a very bad distortion when i try to adjust buffer or sample rate, the error "check your clock source and sample rate" came out after play.. i have been searched a lot of threads,but neither a good way to solve it. keep looking for a help.........:< |
help~~:<
try to update firmware from 1.38 to 1.43 ,but downloads firmware failed.....
Mbox2 Pro on laptop with Win7 | DeliriumE | FireWire & USB Audio Interfaces (Win) | 1 | 01-29-2014 06:50 AM |
MBox2 not recognized by Win7/x64 | dpoberlechner | Digidesign Hardware & Software | 5 | 02-21-2013 12:48 PM |
Mbox2 mini - terrible noise problem on Win7 Cubase5 after upgrading to PT8.0.4 | islovernew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-27-2011 09:43 PM |
Error -1115 has suddenly started with PT LE 8 MBox2 setup - what can it be? | daninpaddington | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-19-2011 07:01 PM |
Mbox2 Mini DAE 1115 error | decayd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-14-2009 03:26 PM |
