Tips needed on remix techniques - help!
Greetings all,
I have a chance to do what could potentially be some pretty high profile club remixes of some R&B tracks. The trick is to get the vocal tracks up from about 85 bpm to 120 bpm. When I change the tempo using Serato Pitch 'n Time, it works great, in terms of sound quality. But then the performance clearly sounds speeded up. Not in terms of pitch, just timing, eg. vibrato sounds super fast. The DJ I'm working with (who is not technical), maintains that there are ways to process the vocals so that you effectively change the tempo, but without having it sound like a super sped-up performance. If anyone has any tips I would really appreciate it. Thanks! - Steve |
Re: Tips needed on remix techniques - help!
Hi knewbee,
In this case, I guess the best solution would be to have them sing it for you at the new tempo... If that is out of the question, I would rethink my approach to the remix. Don't try to do a sped-up version of the original. Just take little pieces of vocals (key elements, hooks etc.) and have fun with them. Fill your sampler with them, and bring them in here and there, you know, "Prodigy or Moby-style"). Does that sound like a good idea? Yaro
www.cmy.pl |
Yaro,
Thanks for the response. Getting the artist in to record the vocals again would be well nigh on impossible. I'm not sure there is a way to get a vocal "transparently" from 85 bpm to 120 bpm, especially if there is strong vibrato, and lots of what have become de rigeur r&b trills and curlicues in the singing. I was just wondering if there might be some approach I was missing. The sample idea is a good one. I'll have to load up some of the vocals into SSC and see what I can come up with... Anyone else...? |
It might sound wierd, but instead of speeding the vocal up (if you remix @ 120 bpm), try slicing the vocal where it hits off of the beat, slide these splices on beat with your new tempo map. Same trick if you took a voice-over or something that wasn't recorded on any kind of tempo, sliced it up (in strategic places), moved it to a tempo map, and now it sounds like the voice is rapping. Hard to explain.
www.hardnoxproductions.com |
I'm not 100% sure on this, but doesn't the Melodyne software allow you to draw vibrato in and out?
AutoTune removes vibrato. AT can also create new vibrato.
If it's any consilation, I hardly ever hear a dance remix that doesn't have that annoying sped up sound which makes me want to vomit (sometimes ).
I would be curious to try using recycle to space out the vocal phrases to the new tempo, then maybe process the parts with seratto. Autotune might not be a bad idea either. Just for the record, I have no experience doing any of this, just giving my thoughts. Oh, wonder if the vp9000 would be useful... |
www.extensivemusic.com |
try beat detector in PT
You could slow down the vocal a little, and speed up the track the track a little. in essence cutting the timing in half.
maybe like to 70/140. The only other way I know, would be to use combinations of Pitch&Time, and hardcore editing_treating each line/word seperately depending what it needs to make it work.
Jerry Nashville, TN |
White label remix album techniques | nuancerec | Tips & Tricks | 0 | 12-06-2005 11:58 AM |
vocals tips and techniques | Xone | Tips & Tricks | 7 | 08-06-2005 03:49 PM |
Remix Tips - from TV to Theater. questions... | dkrz | Pro Tools TDM Systems (Mac) | 9 | 11-08-2003 07:28 AM |
I came here looking for Tips & Techniques... | homerg | Tips & Tricks | 4 | 02-14-2003 06:46 AM |
best of DUC tips & techniques | NY909 | Tips & Tricks | 0 | 11-25-2002 04:29 PM |
