Tab to MIDI note in Midi Editor
How does one tab to next MIDI note in Editor nowadays?
Tried Tab-to-transient option on and off but PT just teleports me to the very end of the session or to the very last note in the last midi region when I Ctrl+Tab. Trashed PT prefs & database files, Even read the manual and still cant get it to work. I'm on PT HD 9.0.3 on Win 7 x64 |
Re: Tab to MIDI note in Midi Editor
Well... it seems that there's no way to tab to the next MIDI note in the MIDI editor... The only thing that works here is in the edit window, with Tab to transients enabled, on a MIDI or instrument track viewing Regions, I can tab from a note to the next one.
It could be a nice feature to add though. EDIT: Ok, I've just realized that you can tab to next MIDI note when the region containing the MIDI is on an instrument track (with tab to transients enabled).
Matthieu Bourque PT Ultimate 2022.10 on macOS 12.6.1 Last edited by mbourque; 09-14-2011 at 07:36 PM. Reason: Correction |
It used to work for sure but now it doesn't in neither midi or instrument tracks.
I guess it's a bug then, don't know if it's fixed in 9.0.5 but I had to downgrade back to 9.0.3 because of all the bugs. |
Does the MEW contain the Edit Insertion/Pencil Enabled?
Aaron Mulqueen - 001 HD Native |
Yep.
PT acts really weird for me currently. Tab to midi suddenly started working in one region and in another it skips notes or jumps waaay back to the end of the timeline. Totally erratic and unpredictable in many differrent sessions. |
I suggest you create a new partition and install Windows then Pro Tools. If you have a clone this would make the procedure easier.
Midi / Instrument - First note doesn't copy properly in editor | echopathy | Pro Tools 9 | 18 | 07-06-2016 04:27 PM |
MIDI editor: display note "names"? | mike_mccue | Pro Tools 9 | 5 | 11-12-2012 04:35 AM |
MIDI Editor should hide notes note in clip | melino | Pro Tools 10 | 0 | 06-30-2012 02:36 PM |
Midi 101 really missing? Set high note/low note on track's input | robinsonsdca | macOS | 4 | 11-10-2011 01:23 PM |
Midi editor cutting off note trails | gamwtonxristo | Virtual Instruments | 1 | 07-29-2010 04:52 AM |
