Old 10-23-2014, 10:08 AM
mitchgh mitchgh is offline
Default Virtual instrument problem -- Mini Grand and Boom
I'm setting up a new computer (MacBook Pro running OS 10.9.4) with Pro Tools 10.3.9.
Two virtual instruments are problematic, both apparently unable to remember a path.
When I load Mini Grand, I'm told "The Factory Content Was Not Found" and I'm asked to browse. When I do so, and direct PT to Applications/Avid/Avid Virtual Instruments/Mini Grand, the content does load -- but ONLY ONCE. When I next open the session, I have to go through the same procedure again. And if I change instruments during the session, returning to Mini Grand, it won't load at all.
Boom acts the same, but it will let me go through the procedure again during same session.
Help please?
Old 10-23-2014, 10:27 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: Virtual instrument problem -- Mini Grand and Boom
Have you tried setting the Set plug-in default to: factory and the Save plug-in default to : Root settings folder?
You find them under the Settings Preferences by click on the small arrow down to the right of the presets menu in the plugin.
PT can't find Xpand2, Mini Grand, or Boom patches DaleB Virtual Instruments 3 09-07-2014 02:30 AM
Boom and Mini Grand Crash PT 8.0.4 paulred7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-11-2013 10:29 AM
boom,mini grand and xpand errors? update 10.3.2 bonzerboy Pro Tools 10 1 10-31-2012 07:23 AM
Mini grand, Boom and xpand problems bonzerboy Pro Tools 9 3 11-26-2010 07:51 AM
Problems With Boom and Grand Piano Virtual Instruments twiszted689 Virtual Instruments 6 10-14-2009 02:37 PM
