Old 05-10-2021, 08:09 AM
briaboy briaboy is offline
Default clipping lights red - normal?
Hi - is it normal for the "clipping lights" to be red on these two audio channels? I just created them, connected paired Rode condenser mics, and the lights immediately came on red. Screenshot attached.
Thanks!
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 05-10-2021, 09:36 AM
BScout BScout is offline
Default Re: clipping lights red - normal?
no.
But you could have peaked the input meters when you plugged the mics in.
If you clear the clip lights, do they return?
If they do, you have a problem with your audio interface.
Old 05-10-2021, 11:24 AM
The Weed's Avatar
The Weed The Weed is offline
If you had the channels assigned to the mics, plugged in the mics and turned on phantom power, then yes, the tracks will probably clip.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-10-2021, 11:46 AM
Cleared and fixed, thanks!
Edit window visual clipping and audio clipping question... Jakay Pro Tools 11 4 07-22-2015 06:52 PM
Normal Levels from Pre amp, Clipping Pro Tools tbystedt macOS 0 03-03-2013 05:36 PM
How much clipping is good clipping ? jaunmanuek The Drum Room 9 04-12-2010 04:49 PM
blue lights or green lights when loading up... zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-15-2007 01:58 AM
is this normal? mr razor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-12-2006 04:34 AM
