Old 08-22-2003, 02:19 AM
chrille2 chrille2 is offline
Default Workspace problem dae-43 error PT6.1
when I try to drag my ordinary wav files from the workspace window into the session I get DAE error-43 on an anyfile I am trying to drag in.
These files can still be imported correctly or added correctly when I do it in the region meny, but draging them from workspace gets this dae-43 error
My sessions are bwf and PC-MAC compatible
please help.
Christian
Old 08-28-2003, 03:21 PM
PaulV's Avatar
PaulV PaulV is offline
Default Re: Workspace problem dae-43 error PT6.1
At what point do you get this error? Is it as soon as you drop the files, when you hit play, etc.? What happens if you drag the file to the region bin, then drag the newly created region to the timeline? Also, what happens if you hold the Alt key down when you drop - this forces PT to make a copy of the file?
-Paul Vercellotti
Digi Engineering
Cheers,
Paul Vercellotti
Avid Engineering
Old 08-29-2003, 04:24 AM
I drag the file from workspace to the multitrack window to drop it, a couple of second later task window shows up wit the dae-43 error
more or less within 10 seconds after i have dropped them into multitrack. it looks like it starts to move it over for a while before the error shows up in task window
Same thing.but i never get a chance to drag the newly created region to the timeline while Pt is trying to move it to regionlist same thing happens task windows pops up with the dea-43 eroor
Same thing, but ontop of what happened before I also get the missing file window popping up
Old 08-29-2003, 04:27 AM
Still...there is no problem importing these files manually from regionlist, This problem only occurs when I drag them from workspace
Christian
Workspace error bryced87 macOS 2 05-10-2013 10:13 AM
Workspace Problem? formfunction Pro Tools TDM Systems (Mac) 0 02-01-2011 02:51 PM
Neo insertion error in the workspace... AudioMatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2008 04:15 AM
Workspace/Neo Assertion Error statik Pro Tools M-Powered (Mac) 2 07-20-2007 11:20 AM
Assertion error in workspace in 7.3.1 garret Post - Surround - Video 1 02-22-2007 01:30 AM
