Old 06-23-2003, 01:22 PM
chrille2 chrille2 is offline
Default translator demo nothing happens
I would like to try the translator demo and push the "try it" button when PT starts , but nothing happens.
When I push the next button, it ask for a hardware key, but honestly, there were no hardware key in the box when i bought PT LE
chrille
Old 06-23-2003, 07:18 PM
zboy2854 zboy2854 is offline
Default Re: translator demo nothing happens
If you press Try It, it enables it, but nothing exciting is supposed to happen. You now have a 15 day trial of DigitTranslator, but it's no use to you unless you try to import or export OMF files. To see if it's working, make a regular Pro Tools session, then under the file menu either Bounce to Disk and the OMF options should be available, or export tracks as OMF.
Old 06-24-2003, 12:23 AM
Ahhh, okey, thanks.
But No option comes up for import audio from OMF, which is what I intended to do.
Does the transloator demo only export to OMF ?
Chrille
Old 06-24-2003, 06:36 AM
You should be able to do the open session command from the file menu, find an OMF file and Digitranslator will automatically convert and open it as a Pro Tools session (assuming the OMF file contains sufficient data). You cna also use the Import Tracks command from the File menu or the Import Audio command from the Audio Region bin menu to bring in OMF files/data into your Pro Tools session.
Pro tools 7.4 turned nito demo after loading demo project!!! mrblwood Pro Tools M-Powered (Mac) 0 05-02-2012 12:53 PM
Demo session/demo template PT8 fridrikur Pro Tools M-Powered (Win) 0 02-15-2010 04:27 AM
Waves API demo. thoughts and clever demo trick! crizdee Pro Tools TDM Systems (Mac) 4 07-10-2007 05:14 AM
Converting Files to OMF with the Demo Translator.. Bhennies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-22-2005 10:54 AM
How Do I Get Rid of Digi Translator Demo? tomhartman Pro Tools TDM Systems (Mac) 2 07-04-2003 09:06 PM
